Ludachris5150 Posted January 2, 2010 Report Posted January 2, 2010 What about 50/50? Thats what I used for mine and it turnd out fine. Does it have to be 60/40? Or is that just easier to use? Rebuild in progress...
Stephen Posted January 2, 2010 Report Posted January 2, 2010 i used lead free. you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
qu1cks1lver56 Posted January 2, 2010 Report Posted January 2, 2010 i heat up the terminal til the wire itself gets hot enough to melt the solder, and push the solder down into the wire until its full of solder. then i puddle it up around the top and make it look good. i always end up with a little melted jacket, but some heat shrink or the boot normally covers it. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
J00bles Posted January 2, 2010 Report Posted January 2, 2010 What about 50/50? Thats what I used for mine and it turnd out fine. Does it have to be 60/40? Or is that just easier to use? the only difference between 50/50 and 60/40 is the ratio of the alloys. 60/40 is usually preffered for electronic soldering, but i couldnt tell you why. it might be the conductivity and such. 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
Ludachris5150 Posted January 2, 2010 Report Posted January 2, 2010 the only difference between 50/50 and 60/40 is the ratio of the alloys. 60/40 is usually preffered for electronic soldering, but i couldnt tell you why. it might be the conductivity and such. Hmm..? Hopefully it dont make much of a difference? I guess Ill find out here in the nex week or so when I get finishd installn!!! Thanks tho Rebuild in progress...
lance_98main Posted January 2, 2010 Report Posted January 2, 2010 Alright so im trying to solder my ring terminals onto my wire. i had the torch on the ring terminal til it got hot and when i touched the solder wire to the terminal, the wire didnt really melt like i have seen it done before. my question is, is the solder wire supposed to melt down the terminal into the power wire or is the fuse between the solder and wire made just on top? and is there a technique i should use? the way i did it was i had the torch behind the terminal. help please! thanksand the solder i am using is oatey solder wire. edit: grammar i usually try to heat up the end of the ring terminal, where the hole through it is, to stay as far away from the wire coating as possible. just a suggestion, and what helps me. good luck. 2000 2dr blazer 15" diamond audio d3 4 cubic ft. tuned @ 32hz (slot port, sub back, port back) debating on a wall or no wall. Shay-kee
S15_Silvia Posted January 2, 2010 Report Posted January 2, 2010 I have some 60/40 acid core solder...how would that stuff work? 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
Guest Posted January 2, 2010 Report Posted January 2, 2010 I have some 60/40 acid core solder...how would that stuff work? "Acid core solder is normally used for plumbing work. It is not used for electrical work."
Anotherguy Posted January 2, 2010 Report Posted January 2, 2010 http://www.harborfreight.com/cpi/ctaf/disp...temnumber=66396 problem solved
Ludachris5150 Posted January 2, 2010 Report Posted January 2, 2010 So 40/60 wont work either? It has to be 60/40? I got every kind but that... If so Im gunna have to go grab some before I redo the 3 ends I did with 50/50, And finish the rest. Rebuild in progress...
