ok im fed up with troubleshooting...im running two amps off of my distribution block, the amp for my comp's works fine no problem with it, but my amp for my subwoofers isn't giving me a lick of output. brand new amp.. any input on what the hell may be going on would be fantastic.. Thanks,
Hifonics Brutus Bxi2010D
sold grounds
power going in but not out
Edited by stephenes89
BIG STICK
2005 Chevy Malibu 3.5L v6 (Impound Status)
(New) Hifonics Brutus BXI 2010D - Courtesy of Maxxonics
(2) Kenwood KAC-8402 Amps for mids & Highs (ok for now..)
Pioneer DEH-P2900MP Head Unit
(4) 6.5" Soundstream Tarantula's
(2) 5.2" Soundstream Tarantula's
(6) 1" Tweeters
(2) Fi BL 15"
BX15 Soundstream Bass Booster
0g Streetwire
after u installed the amp did u put the fuse back in between the batts and the amp lmao.....
but how is your subwoofer wired?
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
fuse is in ( Comp Amp is working )..and so is the remote wire.. i have two 12" QVC's wired at 2-ohm
BIG STICK
(6) 1" Tweeters
(2) Fi BL 15"
0g Streetwire
Does the sub amp light up when the head unit turns on? If it does it eliminates power/ground problems... Otherwise are they both hooked up to the same power/ground source? Like 12v is coming from the same distributor block, and ground is going to a similar spot on the frame? Have you checked if all the wires are in there tight? Have you checked the remote wire going to the sub amp?
If the amp IS turning on, is it going into protect? Is your gain and/or bass boost turned up too high? What kind of amp do you have? Have you taken a volt meter to your amp outputs (maybe its your subs?)
So many questions and possible solutions, throw a bone over here will ya? :(
i know it sounds dumb, but is ur sub output turned on on the headunit
ive done it before..thought my shit was messed up...had the sub turned off on the head unit...lol
i likes me some audio stuff...
is the amp in protect mode? which light is on ? more info would be cool
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Wire Diagram for QVC's < theres the diagram im using now (the first one)
the amp is turning on and the power light is on, on the amp. it is an Hifonics Brutus BXI 2010, everything was turned down when i installed it, when i started to set the gain. i would get to about half way up and the system would start to basically shut off..not the amp my Comp speakers would start to like..crack kind of.. but i never heard anything from the subwoofers (soundstream SPLX 124)
Before I sent my HiFi BXI 2008D back to the manufacture i was having the same problem..was actually the reason i sent it back and they swapped it out ad gave me the 2010D and im still having this problem.
BIG STICK
(6) 1" Tweeters
(2) Fi BL 15"
0g Streetwire
  • Who's Online   0 Members, 0 Anonymous, 7042 Guests (See full list)
