Running a Jensen Phase Linear UV10 head unit with factory speakers. Any volume above 27, the interior speakers cut off
when what seems to be the head unit gets to hot. I'm thinking that i have a blown speaker or hopefully there's an easy
fix for it. If you need to know anything else just ask as i'd like a cheap or easy fix. Thanks for any help!!
Regards,
test the speakers by putting a 9v batter on their terminals.. if the cone moves easily and without a lot of scratchy noise they're probably fine.
Volume levels fading or cutting out due to heat (or voltage drop) is nothing new for head units... my Pioneer does fades but doesnt cut out.
Wish the manufacturers would put better heatsinks on them.
Hammerdown... 1%
Mine cuts off all together until i turn it back down then it comes back in on certain hard beats. I've read elsewhere it could be an ohm
issue but wanted to see what answers i could get here.
what is the impedance on the factory speakers?
Some premium systems could have low impedance, too low for the headunit to run properly on them.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
All my interior speakers are factory... other then the head unit, amp and 15's of course.
What do your settings on the radio look like(bass, treble, etc)... those jensens aren't the best of quality and have alot of problems...
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
My guess is that wires are touching together or the wires are touching the bare metal on the car check your connections to make sure there secure.
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
