Stinger Volt Meter
I think I will bencn test mine on a known voltage (with wire needed attached) to set it, running it up and down voltages , then install it, I will be hooking it to my rear batts
So wait- red goes straight to battery, black is ground, and for blue I can choose the power wire for either my amp or head unit?
Well the remote turn on wire is gonna be the same at the deck and at the amp so you can choose, im doing mine at the amp, red on rear batt and black on rear batt
I will be running all three wires to the trunk for mine, remote to relay bank, power to rear batts and ground to rear batt. I will prob use 3 conductor sheilded wire from work, we gota ton of it
I only have a front batt so that's straight right? I can run red and black right to that
This is what i would do for yours
RED front batt +
BLACK front batt -
BLUE deck (blue) remote turn on wire
or you just could run all three wires back to your amp, or just the +~- to your amp, and then remote to the remote on your deck
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
