my small crx spl build
If u really wanna go all out with the SPL side in the Rex, then I'd suggest making sum tubes for the woofers.. You'll see most of the loudest CRXs(also similar lower SPL class vehicles worldwide) around using the tubes now and are extremely successful doing so.
was gonna suggest this.
but i wonder why no oneuses these for musical beasts :unknw:
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
cool build man, just one question.
you said 0-600 STOCK???
for STOCK wouldn't you have to be in rear cargo area that and also i know they do not list 4 ohm rating but if your amp does 1365W x 1ch at 2 ohms(perr DD website) how would you be in 0-600w?
not trying to knock your build just i am 601-1800 STOCK and i know what a pain alot of those rules can be.
1996 GMC YUKON 2dr
Eclipse cd5000
six- Soundstream T5 12's in 13^ft tuned to 30.4hz,43.04hz, and 53.53hz soundoff
149.8 on TL in kick,150.0 SEALED in kick 147.8 SB4
3 RF T5002's--------------going to 3 Soundstream DTR1.3400D's
two- Stinger sp1000's----going to two- BATCAP 4000's
2 140 amp alternators---going to 300amp Ohio Generator
2 runs 1/0ga, big 3-------going to 4 runs 1/0g + and 3 runs 1/0g -
MB Quart QSD 6.5's in doors---soon to come
my build log HERE!!!! check it out!
Aeroports, aeroports, aeroports. Also in that power class you would have been better off with 2 3515s. The 95's will be sleeeeeeping.
10.x volts fo' life!
hmmm where do you think the box is rear cargo area behind the b-pillar and lower than side window line, and why would you even throw the what the amp is rated at 2 ohm? The m3 is rated at 600 rms at 4 ohm.
For everyone making suggestions this build was just thrown together in a weekend to prepare for a show on the 21st. I had the equipment already on hand so I didnt have to drop any cash which is the reason im running in a lower class and running these 15s
OK you are right... i was up late and had a brain fart... two seater, so yes cargo area...and very obvious...sorry :fool:
as far as power class reason i said 2 ohm is because on digital designs website the specifications do not show 4 ohm power, only 1 and 2ohm, but still very weird that the amp would MORE THAN DOUBLE power from 4 ohm to 2 ohm going from 600wrms to 1365Wrms at 2ohm
i haven't heard of an amp doing this before, ESPECIALLY when you stop to consider that even near double power again to 1 ohm doing only 2400W continuous??????
600w----4 ohm
1365w--2 ohm
2400w--1 ohm <<<<that part just didn't add up to me, but if you are 100% thats cool
1996 GMC YUKON 2dr
Eclipse cd5000
600w----4 ohm
1365w--2 ohm
Its cool man all dd amps are not rated very high at 4 ohm look at there testing archive. There are some bad amps whom have crazy low 4 ohm ratings look at sundown 4500 its rated a 900 watts at 4 ohm then 2000 at 2 ohm. Some of the American bass amps are the same way.
Nice !
I need to upgrade my Alternator on my 1990 Crx..
where can I get one that puts out about 180 amp @ idle ?
1990 Crx - Clarion DRZ9255 - Zapco Studio 50 & 100 - Kicker nd25a - Morel Elate 6
1991 Civic - Alpine 7909 - Zapco Studio 150 - Zapco z300C2 - Boston RC61 - Mtx slx2 - Kicker s12D sub
