DDlincolnon22's Posted February 20, 2010 Report Share Posted February 20, 2010 I hope someone here can help me out cause I am completely lost with this one. A friend of mine called me up today and said he got some new equipment and plans on installing it tomorrow. When he told me how he is planning on wiring it up I kinda stopped and scratched my head. He told me he was going to wire it straight to the alternator. I was like why? He told me that way it gets full power when it demands it. My question is what kind of effects is that going to have on the amp? I don't plan on trying this on my stuff, I'll stick with wiring it to the battery. But I am also curious as to what kind of stuff he should expect to happen. Can anyone answer this for me? Quote Team Digital Devastation My on-going 9518 build Link to comment Share on other sites More sharing options...
kanes_disciple Posted February 20, 2010 Report Share Posted February 20, 2010 I definitely dont think its a good idea because his alt will be putting juice to his amp and not charging his battery. Quote Kenwood Excelon KDX-693 Head Unit Kinetik HC600 Powerbass 6.75's in front doors Powerbass 6.75's in rear deck Powerbass 1000.1D Powerbass 400.4 2 SA-12 inch Sundown Audio Subs 0 gauge Power Wire and Big 3 Custom Amp Rack Code Alarm with remote start Stinger Digital Volt Meter My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/ My youtube channel http://www.youtube.com/user/kanesdisciple Link to comment Share on other sites More sharing options...
Namosh Posted February 20, 2010 Report Share Posted February 20, 2010 He won't be gaining anything by doing that. Think about the power wire running between the alt and the battery...If you hook to the alternator, you are still hooked to the battery via that cable. If you hook to the battery, you are still hooked to the alt via that cable. Quote My Ram Quad Cab Blow-through Link to comment Share on other sites More sharing options...
nosey1 Posted February 20, 2010 Report Share Posted February 20, 2010 I hope someone here can help me out cause I am completely lost with this one. A friend of mine called me up today and said he got some new equipment and plans on installing it tomorrow. When he told me how he is planning on wiring it up I kinda stopped and scratched my head. He told me he was going to wire it straight to the alternator. I was like why? He told me that way it gets full power when it demands it. My question is what kind of effects is that going to have on the amp? I don't plan on trying this on my stuff, I'll stick with wiring it to the battery. But I am also curious as to what kind of stuff he should expect to happen. Can anyone answer this for me? well first of all an amp requires 12 volt power and ur avergae alternator puts out anywhere from 13 to 14.7 volts so in my mind it seems he would be over powering the am causing it to blow all the time Quote Link to comment Share on other sites More sharing options...
Mosin Posted February 20, 2010 Report Share Posted February 20, 2010 well first of all an amp requires 12 volt power and ur avergae alternator puts out anywhere from 13 to 14.7 volts so in my mind it seems he would be over powering the am causing it to blow all the time Really? Quote Derp. Link to comment Share on other sites More sharing options...
CaPRiCEx383 Posted February 20, 2010 Report Share Posted February 20, 2010 well first of all an amp requires 12 volt power and ur avergae alternator puts out anywhere from 13 to 14.7 volts so in my mind it seems he would be over powering the am causing it to blow all the time :01nocomment8so: Quote 90 Nissan 240sx Avic z-140bh Audison SR4 Audison Voce 6.5s CDT es-20 tweeters Sundown 1500v3 (2) DD 9510's 3 cube box 2 6" aeros XS Power D2400 & Xp950 Skyhigh/Knukonceptz/Rockford Fosgate wiring More Coming Soon.. Check my builds below. 97 Civic Hatch Build 86 Caprice Build you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion Link to comment Share on other sites More sharing options...
bassl0va Posted February 20, 2010 Report Share Posted February 20, 2010 well first of all an amp requires 12 volt power and ur avergae alternator puts out anywhere from 13 to 14.7 volts so in my mind it seems he would be over powering the am causing it to blow all the time If you draw it up you'll see that there's no difference. As long as he has done the big 3 there wont be a measurable difference. Think of it this way, you measure your voltage from your battery, and when the engine is going the alt is charging the battery with 13.8v (or more) and the volt meter says 13.8v (or whatever the alt is charging the battery with.) So he might as well do whatever is easiest. My first post Quote My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades. Link to comment Share on other sites More sharing options...
Neo_frog Posted February 20, 2010 Report Share Posted February 20, 2010 well first of all an amp requires 12 volt power and ur avergae alternator puts out anywhere from 13 to 14.7 volts so in my mind it seems he would be over powering the am causing it to blow all the time Holy fucking shit balls. I've been doing it all wrong. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
splzx3 Posted February 20, 2010 Report Share Posted February 20, 2010 well first of all an amp requires 12 volt power and ur avergae alternator puts out anywhere from 13 to 14.7 volts so in my mind it seems he would be over powering the am causing it to blow all the time joo fail hard core next tym u want 2 help make sure u know wut ur talkin about Quote ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum. Link to comment Share on other sites More sharing options...
DDlincolnon22's Posted February 20, 2010 Author Report Share Posted February 20, 2010 Thanks for all the quick responses everyone. I'm not gonna tell him what he should or shouldn't do, It's not my stuff, I was just curious as to what would happen. Quote Team Digital Devastation My on-going 9518 build Link to comment Share on other sites More sharing options...
