You know you're a basshead WHEN
When you acquire a 'skill' for stripping large gauge wire just enough to get through the insulation, but not lose any strands.
I strip 18 ga wire with a scissors. :P
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
When you have an "emergency bass song" shortcut on your phone for when you pull up to a light and someone else is bumpin... and you wanna show them what's up.
2007 Pacifica
true story.. when you cuddle naked with your 2 VVX-12's and amplifier :)
wooohoo!
-Acura RL 2005. Blue.
-Stinger Expert Roadkill..Trunk only
-(2) Skar VVX-12's D4 coils
-Dual slot ported to the left custom box tuned @ 32hz
-Audioque 1200D amplifier
A tribe called quest... ftw
You know your a basshead when you try to talk to a friend about an issue your having with your system, and when your done explaining, they ask what excursion means.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
When you're 6' 2" tall in a single cab mini-truck, yet the bench seat is pushed all the way forward to make room for the sub box
2008 Toyota Corolla
-Skar VVX 12 D4 (2)-Skar SK1500.1-Pioneer DEH-80prs
that's for the teeth to do. just bit down a bit and pull and done, quick, easy, and you dont need a tool.
When you have a sex dream about cutting the VC out of a woofer and having sex with it.
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
lol :rofl:
wooohoo!
Your buddy needs to shut off his system to use his blinker. HIs voltage meter moves more than his speedometer.
2015 Subaru Outback. That is all, I refuse to touch it.
