Yeah I was gonna say maybe your gas gauge is broke. Drive that bitch around for a few days and if you use more gas than what you just put in then your gauge is broke for sure.
I was thinking ping pong balls..
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
when that happens on a boat its cuz the vent has gas in it and wont allow the air to "vent" out of the tank as you fill it up. it does sound like its building up pressure and not letting it vent out.
sony m60ui
polk mid/hi's
infinity 6000m on tower
fosgate p3d212 x2
fosgate p400-4
fosgate t1000-1bd
im ona boat bitch
My boat build
funny thing is...............slamming fireworks in to the ground with a sledge hammer in mexico is like car audio in california... everyone is doing it but most fail :)
Every time I read a comment you post, or a topic you make... I cannot help to think of how much of a badass you are!!
no i meant ive filled it up to full from 1/4 tank and still had the problem from start to finish, and the last time it happen was like 4 or 5 days ago when it filled it last aside from last night. aside from this i have absolutely no other problems that ive noticed
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
ive tried barely lettin it pump and itd still do it after a couple seconds. the thing blows its load like a 18 yr old virgin on prom night
Are you sticking it in the right hole?
Because it should still stop before it blows because the pump is designed to stop when your tank is full, obviously.
:lol:
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
if u know a plumber, snag one of those pipe cameras. that or take ti to the dealership.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
fuel sender
I have this issue intermittently in my caddy, it will only fill up like 12 gals and I can't pump more then I turn on my car and its a mark short of full. My Caddy is supposed to hold 18gals but only holds 14-15 due to this too, a guy on the caddy forum said its the fuel pump sender.
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
  • Who's Online   0 Members, 0 Anonymous, 765 Guests (See full list)
