melonhead Posted March 26, 2010 Report Share Posted March 26, 2010 Yeah I was gonna say maybe your gas gauge is broke. Drive that bitch around for a few days and if you use more gas than what you just put in then your gauge is broke for sure. Quote Link to comment Share on other sites More sharing options...
z71kris Posted March 26, 2010 Report Share Posted March 26, 2010 I was thinking ping pong balls.. Quote 03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill Link to comment Share on other sites More sharing options...
az73 Posted March 26, 2010 Report Share Posted March 26, 2010 when that happens on a boat its cuz the vent has gas in it and wont allow the air to "vent" out of the tank as you fill it up. it does sound like its building up pressure and not letting it vent out. Quote sony m60ui polk mid/hi's infinity 6000m on tower fosgate p3d212 x2 fosgate p400-4 fosgate t1000-1bd im ona boat bitch My boat build funny thing is...............slamming fireworks in to the ground with a sledge hammer in mexico is like car audio in california... everyone is doing it but most fail Every time I read a comment you post, or a topic you make... I cannot help to think of how much of a badass you are!! Link to comment Share on other sites More sharing options...
Mr. Darkjustice Posted March 26, 2010 Author Report Share Posted March 26, 2010 no i meant ive filled it up to full from 1/4 tank and still had the problem from start to finish, and the last time it happen was like 4 or 5 days ago when it filled it last aside from last night. aside from this i have absolutely no other problems that ive noticed Quote Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward The Revolution Was Not Televised But There Is This Thread(clicky) Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc Link to comment Share on other sites More sharing options...
somerandomguy Posted March 26, 2010 Report Share Posted March 26, 2010 have you tried slowing down the speed at which you're pumping gas? I know my 98 cherokee would stop when it was on full speed, so I had to go half speed and it worked fine Quote Link to comment Share on other sites More sharing options...
Mr. Darkjustice Posted March 26, 2010 Author Report Share Posted March 26, 2010 ive tried barely lettin it pump and itd still do it after a couple seconds. the thing blows its load like a 18 yr old virgin on prom night Quote Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward The Revolution Was Not Televised But There Is This Thread(clicky) Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc Link to comment Share on other sites More sharing options...
somerandomguy Posted March 26, 2010 Report Share Posted March 26, 2010 ive tried barely lettin it pump and itd still do it after a couple seconds. the thing blows its load like a 18 yr old virgin on prom night Are you sticking it in the right hole? Because it should still stop before it blows because the pump is designed to stop when your tank is full, obviously. Quote Link to comment Share on other sites More sharing options...
dwright27 Posted March 26, 2010 Report Share Posted March 26, 2010 Are you sticking it in the right hole? Because it should still stop before it blows because the pump is designed to stop when your tank is full, obviously. Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
BanginOnABudget Posted March 26, 2010 Report Share Posted March 26, 2010 if u know a plumber, snag one of those pipe cameras. that or take ti to the dealership. Quote im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!! Link to comment Share on other sites More sharing options...
Baydestrian Posted March 27, 2010 Report Share Posted March 27, 2010 fuel sender I have this issue intermittently in my caddy, it will only fill up like 12 gals and I can't pump more then I turn on my car and its a mark short of full. My Caddy is supposed to hold 18gals but only holds 14-15 due to this too, a guy on the caddy forum said its the fuel pump sender. Quote 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical Link to comment Share on other sites More sharing options...
