whats the point of that, and wouldnt it be hard for the RCA to slide on?
Some people have an issue with plugging in and unplugging rca cords when the stereo is on.
When they do this and they touch center pin of the rca (which is a positive signal) to a grounded out service such as an amp.
Some headunits will blow the pre out.
Grounding the outer rca will fix the problem.
im totally lost what does this solve the noise u hear sometimes when the engine is on or using power windows??? if the pre-out is blown this will fix it? can this mess up a highs amp if your unplugging them while the deck is on? reason i ask is my highs amp starting making my highs speakers go in and out all crazy and no music came threw them just sound waves and static and the amp blew the fuses and stayed on protect i unhooked my rcas while the headunit was on and then plugged them back in and i seen a arc to the amp from the rca when i plugged it in
I ground my head unit separate from the harness. Theres a nice spot for it. As for noise...I have shitty Scoche RCAs that hiss near any wire. My next upgrade will be some nice ones as it is very difficult to run my RCAs far away from any power wire in my car....too effin small and cramped :P
Eclipse cd7000
What brand of RCA's are you talking about, the wire in between them may be the built in Remote wire some RCA's have nowadays.
no that wire is a ground. you are supposed to ground one end and leave the other open it is for sound cancellation it helps the rcas have a better signal. have you ever heard of not running you rcas and power wire down the same side? so why would you run the remote wire (which is a live power wire) right in the middle of your rcas. think about it
yup he's got the right idea. not only that but since remote and RCas are on separate sides of most amps you couldnt cut the wire the same length and expect it to fit.
Eclipse cd7000
Um, no. When the first set of the Knu RCAs came out with the wire, it was a remote, I know cause I got one of the first sets directly from the owner, it is a REMOTE wire.
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
anyone?
i know my pioneer had a separate ground other than the harness. nice black wire with a spade already on it for me.
  • Who's Online   1 Member, 0 Anonymous, 1611 Guests (See full list)
