so after months of not using my house comp ( got a laptop) i decided to hook it up in my room to my tv using the Hdmi out on comp but it wont work can anyone show me a how to
to get it to work for me?
R.I.P!
(Nov-29-2009)
92 explorer
current build
you need help getting the computer to work with the tv or the tv to work with the computer?
i believe i need help getting computer to work with the tv
when i go to the hdmi input it says no signal
R.I.P!
(Nov-29-2009)
92 explorer
current build
Posted (edited)
damn that sucks....tv is on the right setting? HDMI, have you tryed it before? (using the comp with the tv)
Edited by BeatBox
Posted (edited)
my hdmi works fine i use it all the time with the 360
i dont think the computers giving a signal to the tv
i go to my settings and it says only 1 monitor is hooked up (tv using monitor out)
edit- no i've never used this comp with tv but i dont see why it wouldnt work tv has hdmi out so it should be plug and play shouldnt it ?
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
Plug and play... Depends which OS and which video card really.
If you power down the computer hook up both a monitor and the TV and turn it on does the TV do anything at all during the entire boot up process (flash, change color anything)? What kind of video card is it and do you have a utility installed from your video card manufacturer (ATi, Nvidia, Intel)?
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
simple simple, check to see if the latest display drivers for your laptop are installed. plug the cable in to the laptop and tv then if it does not auto adjust press your FN+F4 keys. FN is function (usually right by the windows key on the keyboard) and F4 is the Display key, at least mine is F4. you should see on one of the keys if its not F4 a box with a line on each side, thats the key you want. let me know
01 GMC Sonoma 4x4
RF T1500.1bd
DC LVL 4 12"
go into screen resolution *if on windows 7* can right click on desktop and go into it, and click detect if you have a regular monitor hooked up.. i dont know if your running ati or nvidia but in ati you can go into the ati catalyst and make sure force tv detection is hooked up as well
Team_DC-Derrick's Youtube
Team DC Audio
  • Who's Online   0 Members, 0 Anonymous, 1129 Guests (See full list)
