i was wondering if there is any place at all in michigan that will do a outer rim repair. i took a pothole and lost 2 tires and ended up with 2 rims with an indent no wider than 1/4in on the lip.
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
so what your saying is you need a rim job
ha ha
but on a serious note i cant help ya
R.I.P!
(Nov-29-2009)
92 explorer
current build
Is it an aluminum or steel rim.
I know I checked countless places around me and researched the net a bit, and always seen that steel rims can be bent back to shape, but an aluminum rim will just break out, or crack, and you cant really heat the aluminum hot enough to bend it straight without it melting (around 800-1500degrees F) depending on the alloy.
Edit: if its a stock wheel (steel or aluminum) your best off just going to a junkyard and buying a new one for $20-$50.
But if its an aftermarket bling bling rim, and it still hold air, I wouldnt mess with it honestly. I wouldnt take the chance having someone claim they can fix it, heat it up and melt it beyond the point of it ever holding air again, and messing up the chrome plating or polished finish.
My $0.02cents worth is done :)
ha ha
you nasty bastard lol. theyre chrome 18s and the rims arent bent or anything at all just have the indent
well i would keep them as is if i couldnt find a shop that could pull it off. cause if i couldnt id just go be a follower and buy 22s XD since im leavin MI anyways kik
pics? i wouldnt mess with it unless its a problem or VERY noticeable, theres a shop near here that send them out when they are cracked to get fixed, they prob can do it. $90 to fix it....but shipping it to the shop and back to you wouldnt be worth it personally
I know a girl whose dad owns a wheel shop in Melvindale. I can ask her if they fix rims. If I remember correctly, she told me a story about how she messed up one of her rims and her dad fixed it relatively easily. I go to school with her, so if I run into her tomorrow, I can ask.
yeah theres also a guy that fixes wheels around here, outta his garage but havent seen him in a while. he usually drops by work(discount tire) every once and a while
