OrionStang Posted April 8, 2010 Report Posted April 8, 2010 When checking the speaker output voltage on an amp, is it normal for the dmm to read a negative number with the gain all the way down? Mine shows -##.# and then jumps up to around 100 as I slowly adjust gain. I got the gain hardly turned at all and the voltage is over 100. SMD Super Seller My Feedback Thread
t-money Posted April 8, 2010 Report Posted April 8, 2010 sometimes it will but like -0.03 thats normal 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
OrionStang Posted April 8, 2010 Author Report Posted April 8, 2010 Nah man, this shits between -50 and -10. SMD Super Seller My Feedback Thread
OrionStang Posted April 8, 2010 Author Report Posted April 8, 2010 bump for help. SMD Super Seller My Feedback Thread
n8ball2013 Posted April 8, 2010 Report Posted April 8, 2010 what do you have your dmm set to? ac? DC? etc THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
P4killer_ Posted April 8, 2010 Report Posted April 8, 2010 Check the connections on your leads/speaker terminal if their loose it will read funny. If al else fails check the fuse on the dmm sometimes my dmm starts acting stupid and when I change the. Fuse its good. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
audiofanaticz Posted April 8, 2010 Report Posted April 8, 2010 Your DMM leads maybe shot. Cheching for amplifiers output put voltage you need to use A/C volts, NOT DC volts. Not really sure what you are using.
OrionStang Posted April 8, 2010 Author Report Posted April 8, 2010 Meter's on AC. I haven't tried the fuse yet. I never had any problem using it with any other amp, but maybe it doesn't like the Stetsom power. SMD Super Seller My Feedback Thread
audiofanaticz Posted April 8, 2010 Report Posted April 8, 2010 Are your batteries in the meter good? I know I had a misfortune a long time ago with dead batteries. Meter read 1.05ohms for sub wiring, when it was actually .2 ohms. Amp lasted for a few days daily street beating at .2 and then poof! LOL If you have a spare pair of test leads for your meter, try swapping them. I know sometimes from them getting wrapped up around the meter the wires fray and get mad resistance and can give very false measurements. But you can put the meter on ohms, and touch the black and red together and if you have a lower ( 0.5 or less) ohm range they should be fine, well decent.
