Here's the deal.. I bought 2 12" Kicker CVXs with a box from my buddy. Subs were tested and bump hard.
I also bought just a temporary Fusion 2000watt mono amp until I can buy my Hifonics Brutus. I am running 0awg for Power/Ground and for some reason... This doesn't bump AT ALL!!!
The subs move, but move sloppy.. No air is really coming out of the port and the sound quality is just shit. Hardly hits any notes at all. Sometimes when you turn it up it seems like the subs turn themselves down, but the amp never goes into protect mode.
I was thinking it was the amp, but I'm not sold because it just came out of my friend's system running 2 12" Type-Rs and this amp rocked those subs! The whole reason I even bought the amp was because I have seen it bump subs!
I ran out of ring terminals so my ground is bare wire connected to a seat bolt in the back of my Expedition, so I was thinking it might have a bad ground.
I also thought it might have been the used RCA's I got with this wiring. They are nicer gold-plated RCA's, but wasn't sure.
Any ideas at all? Took a multimeter to everything, RCA's tested fine, ground was re done but still no terminal(until tomorrow when shops are open) so I'm stumped. I'm guessing it's the crappy amp but like I said, it was just temporary. Buddy won't buy it back from me now.
2003 Ford Crown Victoria P71
2 12" Kicker CVX's
Audiopipe AP15001d
Stinger SR80 Isolator with DieHard 1200CCA battery
Streetwires 0awg
Secondary - 1998 Ford Expedition XLT
That's weird man. At least you KNOW the stuff works. I would say double check all your amp settings and hu settings. The hu outputs might be the problem. If your running a hi/lo maybe check the outputs and peg them if you can.
Edited by baaudio
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Subs are wired perfect to 2 ohms in the box. I know the kid who had the amp before me had his subs at 1 ohm, but come on my subs should STILL be bumping harder.
It's very strange. and what do you mean by Hi/Lo outputs? My Head unit is a JVC KD-S100. I have seperate RCA Subwoofer outputs and more different RCA inputs for A/V shit.
Oh, and tomorrow, I'm adding a second battery with a Stinger isolator.
Edited by abaddon
2 12" Kicker CVX's
Audiopipe AP15001d
Streetwires 0awg
You grounded with bare wire to a seat bolt. Its the ground.
1999 Pontiac Sunfire
Alpine CDA-9886
Sundown Audio SAZ-1000D
Sundown Audio SAX-50.4
Rainbow SAC 265.25 Components
Image Dynamics iD12
Optima Yellow Top
SQFire FTW.
Are you sure you have the positive wire from the subs running to the positive terminal in the amp and the negative to negative, or if there's a phase switch its not on 180. This sounds like the problem.
Edited by vengfuldev
Start out boxy, shape as you move along.
Dc Audio
Team Fur
i have the same headunit :P ^^^ yea i'd say its the ground cause im running a kicker cvt (just for now) of a rf 500.2 with a body ground, no trouble at all. sound comes out nice and clear
My F-150 Build (So Far)
2 DC L3 10's
Kenwood KDC-X794
(4) Selenium ST200 (Highs)
(2) RE X8 (Mids)
Sundown Sub/Mid/High Amps
Shuriken Batteries
Knu Wiring
My Feedback Thread
A hi/lo is an adapter you put in to convert speaker wires into rca outputs. This is only on stock hu that they do this. But ya I agree^^^ ground is the problem
Team NWSPL
baaudio Build Log
seat belt bolts suck...lol wait until u get a real ground with a ring terminal and re check.
also make sure your filters on the amp are set right. 80 for lpf usually...
check fuses and wiring. did u try adjusting the bass volume from the head unit?
Eclipse cd7000
ive barebacked wire for ground before.. so thats not the problem.. unless its a bad ground spot..
i would check your head unit..
take your volt meter and put it on dc volts and play a song with the woofers not attached.. check for dc voltage coming out of the amp.. dc volts = bad
then swap to ac volts and see how many volts its putting out.. if any..
double check the ohm load coming out of the box.. if its still 2 the woofers would have to be dual 2 ohm woofers
if they check out
take a 9 volt battery and run it to the terminal on the speaker box.. positve to positive and neg to negative.. keep it on there for a second. only long enough to see which way they move..
if one moves in and one moves out.. theres your problem.. if they both move the same way. well then your sol lol
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
