Alright so I have a speaker/sub combo that is powered from the wall outlet, the fuzzy interference sound is only when they are turned on and at low volume. Ive tried plugging them in to different jacks on my computer and its all the same. Is there anything that will easily fix this or do I need to buy a sound card or new speakers? Fyi its a PC not a laptop.
Also all my grounds and screws for the motherboard are all tight, so I know its not that.
Thanks
Edited by Awhitewookie
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Try twisting the mini plug and see if the sound changes. You might just need a new cable.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
Might be a bad or broken ground inside the plate amp, have you tried using it off an mp3 player or another computer to see if it is coming from the speaker/sub combo?
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Just tried it and nothin
Crap I'll have to find that cable
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Alright just plugged them in to my mp3 player and there is no fuzzyness, and also plugged into another computer with perfect clarity. I'm guessing i just need a sound card?
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
turn down volume in windows, and wave volume as well. Helps a lot of the time. 75-80% is a a good number to stay under.
Hammerdown... 1%
Often times you can configure which port does what on the sound card. Check the software for your sound card to see if it allows you to configure another port for output, if not, as others have suggested, just go get a new cheap card.
Edited by UnderLoK
Pioneer X8500
Second Skin
2 270a Mechman Alts
