atsaubrey Posted May 30, 2010 Author Report Posted May 30, 2010 2 300 amp fuses one to each amp makes me in modified 5 right.. i dont think ill make it enough for a trophy u guys think i shall still compete.. ill probably do a 153 with no engine revving. You have a couple of options actually. Stay in M5 with your fuses (153 is loud and you' be very competitive actually), or you could start playing with lowering your fuse rating and see how long you can get smaller fuses to hold for that 30 second run. Alpine for example downgraded to 2-80amp fuses with something like 12000w on tap.....tey ussually hold for the 30 seconds. lol You got the Term Lab and fuses are cheap, "do the most with the least" is kinda a MECA motto. lol Regardless, your going to have a blast.
mr.p Posted May 30, 2010 Report Posted May 30, 2010 im probably sitting this show out. down to 2 amps DCAUDIO BALLS DEEP
99s10walled Posted May 30, 2010 Report Posted May 30, 2010 I'll go and I'll see who's in mod 5 before I compete that's if I qualify with my wall TEAM FLEX ISSUES Alpine cda 9886 4 AA Mayhem 15"s dual 1.4 1 Dc 9k 10.5 cubes tuned at 36hz 156.1 dash 154.6 meca mod 4 157.0 kick 2 xs power d3100s mechman 270 amp 2011 Ca state champ meca modified 4 and p&p 4.. VIDEOS.............BUILD LOG
ALPINE408 Posted May 30, 2010 Report Posted May 30, 2010 a 153 i can tell you is a 2nd place for sure if Mr.p is sittinig out also try 2 150 amp fuse's that would be mod 4 depending on your how many subs and what size.. for spl part you only need it to last for 3 seconds for your max score to show in drive by you need it to last 30 seconds.. with some testing you can make sure the fuse's last then after the show throw your 300 amps fues's back in 153 mod 4 is a for sure 1st the loudest mod 4 guy in cali is a 151.0 so you could take that spot.. loudest mod 4 in cali sounds nice huh hehehe Have you ever had your woofers blown?
AI James Posted May 31, 2010 Report Posted May 31, 2010 nooo go mod 5, all the cool kids are in mod 5 Ray will be there with the truck in mod5 for shizzle, so youll have at least one competitor to battle it out with
99s10walled Posted June 1, 2010 Report Posted June 1, 2010 2 150 amp fuses and 4 15s will that be in mod 4 their example table is kinda weird to figure out. i would wanna try to get the new record for mod 4 in cali TEAM FLEX ISSUES Alpine cda 9886 4 AA Mayhem 15"s dual 1.4 1 Dc 9k 10.5 cubes tuned at 36hz 156.1 dash 154.6 meca mod 4 157.0 kick 2 xs power d3100s mechman 270 amp 2011 Ca state champ meca modified 4 and p&p 4.. VIDEOS.............BUILD LOG
jg23 Posted June 3, 2010 Report Posted June 3, 2010 Can someone tell me what class I would be in. This is a page with my system. I have a 300 amp fuse I believe. http://www.cardomain.com/ride/3831899/2 2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0 Build Log UBL My YouTube channel
ALPINE408 Posted June 3, 2010 Report Posted June 3, 2010 As long as the fuse is right befor the amp after your second batt that would be street 4 put in 1 150 amp fuse u would drop to street 3 I have to check the amateur classes if u never did meca you cold be in a amateur class Have you ever had your woofers blown?
Ray Posted June 4, 2010 Report Posted June 4, 2010 The truck is up and running again............. I still need to weld up the sheetmetal that got ripped apart from the last time. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
