07 TBSS Fi Team 18's B-Walled 4th
Sorry to hear about your trouble with the XXX amps, I've had 4 of them and never had any trouble at all.
Where did you buy them from exactly?
If you need help I can take a look at the car for you, I'm local
Team Soundstream
Team Xs Power
Team Secondskin Audio
Team Mechman
Thanks man, but I'm adding a ton of stuff in the next week which will hopefully address any potential issues.
I got them from Xtreme who handed them to me from the distributor... They are a dealer. The amps worked fine for a week then all hell broke loose. As I said earlier getting a hold of support was a complete PITA and I had to email Grizz to get a response. Then to get an RMA I had to get my dealer to call because Kevin wasn't returning my calls. It's a riot they say "call and ask for extension 2xx" and when you do the operator always says the same thing "I'm sorry he is on the phone" without fail. I left messages with her and no dice. As I told Victor and Kevin they obviously need more people. I mean what, 2 guys for SS and PA?
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
dam bro sorry about the luck sounds just like me sometimes i gotta buy things or have them repaired 3 times till they work right... but dam your not to far away im down for a meet or if u want help and i ant buzy im down for doing the hard work, thats what i have to do now at dukes anyways
but keep us updated
I can't stop building!!!
4 DC LeveL 4XL 18 Blow Through Re-Build
The newest addition My '97 Ford Explorer Build
My First Build 8 RF P1 12's
My Myspace Add Me
My Facebook Add Me
oh, your a hypocrite too bro.....your mom has my name on her left tit - and you still like her dont you?
If youre masturbating to that sub already, wait until you get a real sub... I think your nutsack will shrivel up.
Wow.
Glad to know theres someone else out there with luck as bad as mine. :drinks:
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
but keep us updated
Thanks man appreciate it. Hopefully it'll be sorted out shortly.
Wow.
Man it's never ending... :drinks:
Pioneer X8500
Second Skin
2 270a Mechman Alts
Trust me, I know.
One step forward, two steps back.
Or so it seems.
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
Well my gimp ass spent an hour trying to get the gate open today, the trim has edges around the bump stops on the gate that make it impossible to get the trim off... After failing for an hour I said screw it and took it to the dealer this morning. Full warranty for another 2 months so I might as well use it. Oh and "my door trim just fell off"... I broke two pieces during the build, they might warranty those too ;)
Should have it back Thursday or Friday 10am at the latest. Once I do I pack up and head down to see Aaron. I'll take some pics of the chaos in the garage later. XXX's are here and DATs should have been here Thursday, but of coarse they didn't actually ship until yesterday so Monday it is... That's a monster PITFA because the XXX's take 1 1/0 and the DATs took 2 and I don't have 300a ANL's only mini's to make 300... :angry: Gotta pick some up before I head down on Friday.
Pioneer X8500
Second Skin
2 270a Mechman Alts
Well I just got back from visiting with Aaron down in Columbus and we put in some serious work last night. Things were playing by 6 or 7am I forget which but OF COARSE the one XXX is still screwed up and Soundstream are idiots... It's still putting current through the case... :angry: Also the HU flaked out and had to be reset 3 times and the remote wigged out too which were all fixed.
At any rate, I have one working and it KILLS how loud a single XXX was before. We screwed around on the TL and it posted up a 140.6 at 28hz (MECA style) running on one XXX at 2ohms (not sure maybe 2200 watts) ;) It kills the lows which I love...
We added between 130-150ft or wire last night, made up the bus bars, and tried to install the dual alts but again more issues, I just have to get my goose neck on my power steering cut down a but, but the one worked all the way home :clapping:
Sorry I don't have more pictures, my buddy was taking them, but I should have showed him how to use the camera because they all came out blurry except these that I took...
Aaron rocks and was a massive help!
Copper 1/4x1 with 4 front to back grounds (rear batts), frame grounds, and alt grounds (all to battey). We also added two more power run to the rear so there is now 4 total.
Rear bus bar mock up, again everything grounds to the front bus bar.
All the wire waiting for lugs.
Anyways, now I just have to kill SS on Monday :bull: Well that and pick up some more hardware.
I had initially planned on running the DATs, but after talking with Bill previously he had said that 15.5 volts is the hairy edge for these amps and well, my truck at start kicks out between 15.2-15.48 in my testing and did a 15.67 when I started the truck after the rear batts had been disconnected for a few weeks and it's making me a bit nervous... The XXX's can take over 18 volts no problem. :(
Pioneer X8500
Second Skin
2 270a Mechman Alts
