MAXSPL_153 Posted May 29, 2010 Report Posted May 29, 2010 have a 97' dodge 318 . it has a P-1SC Procharger , full Procharger intercooler setup , and the Procharger bypass valve . im lookin to pull more boost at lower RPM and or make it a little more noisy . heard hear say about venting to atmosphere from the bypass , or even unhooking the vacume line that goes to the bypass , in turn closing it hence pulling boost much sooner . BUT ...... the thing im worried about is with the bypass closed , after i rack it up and build boost , when i get off of it , the built up boost will not vent through the bypass but backfeed through the procharger . . is this bad ?? could it hurt the motor/ procharger? the loud fluttering noise i hear when the bypass is hooked up is like 10 times louder when i unhook the bypass valve . it sounds bad ass but i havnt had the balls to drive it like that yet for fear of hurting something .. anyone have an idea on this ? if the "back feeding " through the procharger is bad? if un hooking the bypass is bad? im just tryin to make this setup noiser than all hell .. any input would be much appreciated... thanks guys !
EricM9104 Posted May 29, 2010 Report Posted May 29, 2010 Sounds like a surefire way to fuck up a motor. 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
chewie Posted May 29, 2010 Report Posted May 29, 2010 the bypass allows excess pressure out both on and off power.. anyways.. if the bypass valve is hooked to another tube with a length of rubber hose replace most of it with a metal tube.. it will sound a shit ton louder.. and not effect your tune.. 91 dodge colt gt.. 4 custom t600 15s audioque 3500d.1 tuned to 25 hz... stay tuned. blazer stroker 15 brutus bxi2006d terrible voltage drop 145.4@38HZ... SEALED LEGAL Aim: chewieft09 www.t3audio.com carpe diez nuts !! my house is louder than your car...
MAXSPL_153 Posted May 29, 2010 Author Report Posted May 29, 2010 Ok that tube is running back to the procharger inlet , would I leave it like that or block the hole on the inlet and vent the bypass through a metal tube to atmousphere ? Or just turn it down to blow access air down toward the ground ?
mr.p Posted May 29, 2010 Report Posted May 29, 2010 why not run a smaller pulley and up the pressure a bunch and let the bypass let out the excess? DCAUDIO BALLS DEEP
MAXSPL_153 Posted May 29, 2010 Author Report Posted May 29, 2010 Well it has a 3.40 pully on it right now and that's suposed to be good to 8 lbs of boost , but i'm runnin stock heads and rotating assembly , you think the motor would hold up to 9-11 lbs of boost ? Any ideas if it's bad to have the access pressure blow back through the charger ? Cuz it sounds SWEET when the bypass is fully closed all the time
Wastehog Posted May 29, 2010 Report Posted May 29, 2010 If you want louder, get a louder exhaust. The thing your doing is going to fuck up your motor and pc. Just think of the bypass like this.. its your rev limiter on your lawnmower. You take it off, eventually, you will over rev it and blow the motor, same idea. Your blow off is a limiter. It limits how much boost you have, and when its closed, and you let off the boost has no where to go. So, the boost heads right for the source, the procharger, and boom, eventually your setup was worthless. 1985 Chevy Silverado Black and Silver SBC 350/700r4
MAXSPL_153 Posted May 29, 2010 Author Report Posted May 29, 2010 Just got done re plumbing the bypass with PVC pipe routed stright behind the bumper and dumped it stright down to the ground and also plugged the inlet where it was running to origionaly , it's a considerable bit louder and bypass is still functioning like normal ... What ya think ?
chewie Posted May 30, 2010 Report Posted May 30, 2010 If you want louder, get a louder exhaust. The thing your doing is going to fuck up your motor and pc. Just think of the bypass like this.. its your rev limiter on your lawnmower. You take it off, eventually, you will over rev it and blow the motor, same idea. Your blow off is a limiter. It limits how much boost you have, and when its closed, and you let off the boost has no where to go. So, the boost heads right for the source, the procharger, and boom, eventually your setup was worthless. WRONG the reason why the bypass valve is recirculated is to keep his air fuel ratio correct.. see tthe air that comes out of it is metered air.. and if he releases that air anywhere else but back to the intake his truck will run rich for a second then(blow off too much fuel not enough air and then lean because it is sucking in unmetered air through the valve so reconnect it back where it was and replace the rubber pipe with a length of thin metal pipe.. trust me it will be louder. the rubber tube soaks up ALOT of the blow off noise.. and the metal tube will resonate and sound louder.. now for a little background on my knowledge.. i own and have worked on many eagle talons they are turbo charged with a bypass valve.. it takes the blow off air and recirculates it back in front of the turbo.. (same concept as your truck) without it my air fuel ratio meter does exactly what i described and the engine wants to die after i let off and let it blow off.. 91 dodge colt gt.. 4 custom t600 15s audioque 3500d.1 tuned to 25 hz... stay tuned. blazer stroker 15 brutus bxi2006d terrible voltage drop 145.4@38HZ... SEALED LEGAL Aim: chewieft09 www.t3audio.com carpe diez nuts !! my house is louder than your car...
MAXSPL_153 Posted May 30, 2010 Author Report Posted May 30, 2010 Ok man thanks for the tip , I have to wait a couple more weeks till I get back home ( I drive truck for a living) so I'll get me some tubing and post up some updates on here . I was also thinking of adding the procharger "race " bypass valve on there too. I hear that will make a HUGE difference in sound & performance . Think the 400 bucks it cost is worth it ?
