how much port area should i have for 1 12 sundown nightshade 1500rms and a box about 2cubes, i currently have a custom box i made but not sure if i got the port area right for the sub and what not, im at about 29in^2
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
thanks man that thing says i should be at about 39in^2 and im only at 29 so i bet if i build a new box it will sound alot better. what do you think?
I'm sure it will, I've built boxes based off that site's calculations with 45*s in the corners & have been very impressed!...Made 10s beat way harder than i thought they would! :)
Did you notice that calculator did not ask you for the box volume to determine the required port area?
Sorry, I had to say it ;)
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
yeah i did notice that when using the torres calc it pretty much gives you a range determined by box volume. so what is the right way to build it?
Usually, the number that the site gives me is usually within the range in the calc, if the box is too small & port area too big I just use the biggest number in that range....always worked for me...
For that sub I'd do 2.5cubes 40-50sqinches...
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
  • Who's Online   0 Members, 0 Anonymous, 2930 Guests (See full list)
