im putting a battery in my trunk and going to be using 1/0 wire
putting a fuse on both ends of the positive
do i need to fuse the negative as well?
250amp fuse correct?
and do i need to ground it?
thanks in advance
i tried using the search but i can't ever seem to get it to work how i want to <_<
You dont need to fuse a ground
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
no fuse on the negative needed but you do need to ground the battery.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
srry dont mean to thread jack but i was wondering well i have a kinetik 1800 as my rear battery and im wondering is it safe to take the terminals out the battery replace them with screws to attach my wires to the battery...
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Wtf are you talking about dude? lol
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
a battery has 2 terminals positive and negative.. im askings could i remove the terminals and replace them with screws and have my power wire connected like that.. cuz i cant get 0 gauge rings over a battery terminal.. better?
I see. :) My bad brah. Look into these:
http://cgi.ebay.com/ebaymotors/Taylor-Cable-21412-Battery-Terminal-Brass-1-1-0-Gauge-_W0QQcmdZViewItemQQhashZitem5ada5260fdQQitemZ390209888509QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/Tsunami-BT703-2-1-0-Ga-Pos-Neg-Battery-Terminals-/260620761868?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3cae353b0c#ht_1806wt_930
Unless the terminals actually are attached via screw in?
thanks in advance
Since no one is answering this I will....
If it were me I would put a fuse at the front batt, one right before the second batt (its over kill but why not be safe??) And then one after your second batt going to the amp
Then for grounding you can ground it to the frame, or what I would do is run a second wire from your batt in the front. You would do this to make sure that you have the best ground possible. also if you do end up having a second run of wire to the back I would still put another ground to the frame
Hope this helps and I answered everything!
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
double fuse on pos.(250amp or 300) ground that bish. done. :)
Currently:
2015 Evo X WW
Forgestar F14 18s --Rally Armour Mudflaps
ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers
Build:
Crescendo Mezzos x2
Crescendo 800.4, 1500.1
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Sky High Audio Wiring
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded
12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids:
Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit:
knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400
TEAM DEADLY HERTZ!!
Financial Consultant- Charles Schwab
