Need your thought`s about this wall design
Hey guys!
I`m about to start my first wall build and I want it to be a really good one. I have some experience with box building, but from what I`ve heard and read, when building a wall, things change. So I need your opinions/thoughts about this. I`ve crunched some numbers and done some work on sketchup. These are going in the wall btw :)
Here`s the box, net volume of each chamber is about 7.4 cubes, 32hz tuning according to Torres calculator.
Proud member of SMD
My build log
2 DDZ9518
2 DynaBel BF 8501
2 GZ Neo 8"s
154.5@38hz with 2 DD Z9518`s
145.5@40hz with 2 DD 1508`s
My youtube vids
get rid of the MM, the design looks good but i donno what those DD's will like so i cant help ya there
Oh and its nice to see your designing it yourself
EDIT- maybe invert the box so its port on top subs bottom
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
Im working my first wall now and let me tell you , its a learning experience. Im happy I tried it, not happy the way its turning out. Learned a whole lot doing it. Your enclosure looks good. My dimensions and net volume are good, but getting the front baffle to sit and fit right is my biggest issue. It'll be loud, but not very pretty.
SMD Super Seller
My Feedback Thread
I`m from Norway so I use the metric system :) I`ve chatted a bit bit the Norwegian champion in SPL, he recently built a wall for the first time and noticed that the subs likes more volume and the tuning drops down quite a bit (his dropped around 7hz from the calkulator vs real life) He did 156.6@30hz with 4 15"s and about 20kw and had a peak of 159 in the high 30`s. Hope to get atleast a 155 with the new setup.
Proud member of SMD
My build log
2 DDZ9518
2 DynaBel BF 8501
2 GZ Neo 8"s
My youtube vids
ah makes total sense now
R.I.P!
(Nov-29-2009)
92 explorer
current build
What diffirence does that make? just curious :)
Never built a wall or even seen one in person, but I would do some 45's in the corners and some dowels for support. Also I bust a nut every time I see those woofers
Gonna do some 45`s where needed, don`t think I`ll need further reenforcement, as the walls are gonna be 2.5" thick with seperate chambers.
Proud member of SMD
My build log
2 DDZ9518
2 DynaBel BF 8501
2 GZ Neo 8"s
My youtube vids
I'd do port on top. Less restriction as the seats won't be in the way
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Im on the fence with my wall here also, cant decide weather to do woofers on top or port on top. What do you all think sounds better? I personally am not going for numbers just moving a lot of air. Dont mean to thread jack hope it helps you also! :popcorn:
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
  • Who's Online   0 Members, 0 Anonymous, 1374 Guests (See full list)
