My 8x15 In Vw Golf Nearly Done Who Wants Vids !
The subs ive got say 2-4ohms There Dual voice coil
I was looking at the ohm help but still a bit confused...
Can i wire 4 15''s by linking all + and - together into my hifonics 2000d to make 2000@ 1 ohm ???
Please help people i dont want to blow my hifonics amp away or the subs LOL
Thanks for you time
If they are Dual 4 ohm voice coils and you wire Them ++++ and ---- Then your amp would see .5 ohms at the amp..
If They were Dual 2 ohm voice coils and you wire them +++ and ---- Then your amp would see .25 at the amp..
Make this simple for you=....Follow this link,....It has all the things you need to know...
http://www.the12volt.com/caraudio/boxcalcs.asp
How about you go back and change your typeset and size and unbold everything, or I can just delete it.....Please use a little common sense when posting people.....The large and bold and all caps has to stop so that it is easier read by all of us.
Thank you-Roscoe1129
-SMD moderating team
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
OK thanks for your help !!!!
Will hifonics bxi2000 handle lower than 1 ohm ???
The subs just say 2-4 ohms how am i going find out
well I sont know how a sub can be 2-4 ohms, but the way to check is to put a multimeter on the coil and measure the resistance. If you have two coils they are dual (insert impedance here) if not they are single.......
Scientia est Vox
How about telling us what sub model they are so we can find out the specs for it. However from what it looks like you're tring to say is it's a 4 ohm DVC and if those 2 subs like that are wired in parallel you'll achieve a 1 ohm load at the amp.
Dual 2.5" aluminium voice coils
Large foam surrounds
Chromed aluminium baskets
1000w max (500w rms)
200 oz magnets
Freq resp 25-4000hz
Imp 2-4 ohms (says on box)
Tell me what more i need to tell you
(only cost me $250 for all 8)
