lol thanks guys, I think I should just stick to my 1000w rms amp. Maybe If I come across a 1200w at some stage.
I run 2 sundown amps (1500 w for the bass and 320 for front speakers) on stock electrical : stock alt and stock batt. With no problem at all.
But I don't know anything about my alt.
I have upgraded (1/0 and 2/0) ground wire for my batt and for "engine to chassis".
you can try to run a 1500 watts amp.
Music is dynamic, you won't use 1500 watts every time.
get a voltmeter and be careful.
A friend of mine is running 4000 watts for the bass and 600 watts for his speakers on a 120 amp alt and a 5 years old Optima blue (big3 done) without problem. but, at iddle he can't play for too long, he has serious voltage drops. but when driving he stays at 14.4 v easily. with the engine off, he doesn't play more than 2 minutes!!!
Daily driving is different from demoing at iddle or with the engine off !!!
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Just gotta watch how low your voltage drops. Like you don't want it to drop below 11volts.
11v? People have low standards, I don't let my system drop below 13v and I only idle at 13.4v.... thats not cool
on that electrical i wouldn't run more than 1000, maybe 1200 watts with NO PROBLEM. any voltage drop below 12 volts is a problem, so for everyone saying no problem you might want to check that.
i don't see stock electrical in any car supporting 1800 watts without serious drops and clipping the shit out of the amp.
also yes kirill is right, different amps have different efficiencies and even the same smp run at different ohm loads has a different efficiency so you need to take that into account as well.
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
I have no problem holding 12.6 volts on the following install.
At idle voltage is 14.4
big 3 in 1/0
85 amp alt
55 amp hr yellow-top rear
38 amp hr yellow-top under hood
1 sax 100.4 @ 4 ohms
1 SAZ 1500d @ 1ohm
TEAM FLEX ISSUES, TEAM DC AUDIO
2010 California State Finals Champion MECA AS2
2011 California State Champion Meca S2
2011 California State Record holder Meca S2
2012 Meca Mod 4 class 152.5 and rising
  • Who's Online   0 Members, 0 Anonymous, 1044 Guests (See full list)
