150 spl is a measure of pressure how many lbs per in squared
I want to put a glass window in the top of my box and my freind thinks that the wood trim i want to use will not hold, ( be airtite)....
So how many pounds per square inch would it be if i was hypathedically hitting 150 with 2 dc lvl 5 18s on a sound digital 8k
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
glass window? umm glass wouldnt like that too much and is why people need windsheild replacments lol
OMG GOOOGLE
1 psi is equal to 170.7dB and atmospheric pressure is around 15 PSI and 1 atm is equal to 194dB( theorictly, if i measure the spl of the atm at 101,3KPa and atm drop to 0 KPa, the meter is suposed to indicate 194dB) Remember that spl is relative number.
110dB = 0,0009PSI = 0,006KPa
120dB = 0,003 PSI = 0,02 KPa
130dB = 0,009 PSI = 0,06 KPa
140dB = 0,003 PSI = 0,2 KPa
150dB = 0,09 PSI = 0,6 KPa
160dB = 0,3 PSI = 2 KPa
170dB = 0,9 PSI = 6 KPa
180dB = 3 PSI = 20 KPa
190dB = 9 PSI = 60 KPa
194dB = 15 PSI = 101 KPa
Higher is'nt possible in normal atm !!
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
My homie works at a glass place and i was getting in graved ill get some. Pics when im done....
1" thick id like to see that break......
SCSB
Build logs:
OMG GOOOGLE
Haha never looked at google thanks ur the man
SCSB
Build logs:
if its just regular glass and not plexi it has a chance. i dont think you realize how much force/pressure two lvl5's are going to make inside that box
justin smith
1996 mercury grand marquis
20'' bentchi b7 lexani n3000 245/35/20
cactus 5kw at 1ohm dcr(beast)
2 18'' btl's in a 14.15^ft wall tuned to 35hz with 210'' of port
kicker zx650.4
componets in still the works
200amp motorcraft alt
xs power d3100 (beast)
kenwood ddx512 h.u.
you mean my EX? the one I dumped? just remember every time you kiss her that i used to cum in her mouth
and BTW your girl just called me....
pure pwnage
Not to mention the stressed placed on the screw holes.
You also have to take in account that a material will maintain it's structural integrity only passed 2x the diameter of the whole in it.
So a 15" hole would weaken the material about 30" in diameter around that.
If I remember that formula correctly.
I think he just wanted a viewing hole, not as the baffle. So it would probably be fine.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
150 on the dash can translate easily to mid 160s in the enclosure.
I strongly recommend using plexiglass instead just so you can secure the seams stronger.
I drill through the plex to run screws into the wood, and also use a glue/sealer.
The material will hold firm at 1" thick. its the seams you should worry about.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
  • Who's Online   1 Member, 0 Anonymous, 1638 Guests (See full list)
