Rickdod3 Posted August 24, 2010 Report Posted August 24, 2010 Do the running lights work?...Is it just when you step on the brake that they dont light up? If its that them im guessing 95% its the bulb, the bulb would look like its good but most likely one of the filaments in the bulb could be fried Quote Audio Technix Online Customer Service Specialist [email protected]
nCOMP1337 Posted August 25, 2010 Author Report Posted August 25, 2010 well i believe in my last post, i stated that the lights work every way they are supposed to except for when you press the brake pedal, i took bulbs out and looked at them, nothing seems to be busted or fried, but i think i may have a replacement in my glove box, just to be sure i will replace it with new bulbs, but since those lights turn on at night, i would think thats not the problem is there a special wire or fuse somewhere where it tells the lights to turn on when pedal is pressed, maybe i tripped something that goes from pedal to brake lights, but just by exchanging cd players i doubt it must be something else and just happen to not notice it until i was told when i had replaced my cd player Quote
99s10walled Posted August 25, 2010 Report Posted August 25, 2010 Google it on my s10 it says that sometimes after hooking up an aftermarket deck my switch for My cluster lights will go out and mine did.. After like 5 different head units which is weird but got a new one and hasn't busted since.. Quote TEAM FLEX ISSUES Alpine cda 9886 4 AA Mayhem 15"s dual 1.4 1 Dc 9k 10.5 cubes tuned at 36hz 156.1 dash 154.6 meca mod 4 157.0 kick 2 xs power d3100s mechman 270 amp 2011 Ca state champ meca modified 4 and p&p 4.. VIDEOS.............BUILD LOG
Autruche Posted August 25, 2010 Report Posted August 25, 2010 well i believe in my last post, i stated that the lights work every way they are supposed to except for when you press the brake pedal, i took bulbs out and looked at them, nothing seems to be busted or fried, but i think i may have a replacement in my glove box, just to be sure i will replace it with new bulbs, but since those lights turn on at night, i would think thats not the problem is there a special wire or fuse somewhere where it tells the lights to turn on when pedal is pressed, maybe i tripped something that goes from pedal to brake lights, but just by exchanging cd players i doubt it must be something else and just happen to not notice it until i was told when i had replaced my cd player Earlier tonight my friend had a brake light out, the bulb looked fine, but it didn't work. His bulb was a dual filament bulb, and one filament was burnt out. I replaced it and it was fine. If your brake light is also your parking light, then it's a dual filament bulb, and the brake light part may be burnt out and the other one is fine. If that is the case then it might just simply be your bulbs. Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
nCOMP1337 Posted August 25, 2010 Author Report Posted August 25, 2010 thanks ill check the bulbs out today and ill google for some info on my car too btw i got an 99 olds alero Quote
wL<3bass Posted August 25, 2010 Report Posted August 25, 2010 Hmmm sounds like my Blazer the stereo rattled the pins loose in the switch for my hazard lights and it caused my parking lights to work but when I pressed the brake I had nothing but the top 3rd brake light... Sometimes I would or wouldn't have turn signals... If I played around with the switch it would sometimes work. Quote Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
Rickdod3 Posted August 25, 2010 Report Posted August 25, 2010 Im 98% sure its the bulbs...all you can do is try out some new bulbs...Im not sure but I dont think a set would be more then like $5-$10 Quote Audio Technix Online Customer Service Specialist [email protected]
nCOMP1337 Posted August 25, 2010 Author Report Posted August 25, 2010 alright found the issue, the guy about the dual filament was right i checked them but i found out that even though it looked like it was connected, one of the filaments was all there but the connection was just barely not touching, lol dunno if the subs rattle it off, or if it just broke partially due to other factors, i doubt the subs would be at fault i do not have much of a system in the way of power, just running about 200rms to two 15 CVRs Quote
Ray Posted August 25, 2010 Report Posted August 25, 2010 bulbs. You said the third still worked. which means the circut works. Replace the bulbs. Prob 1157's Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Rickdod3 Posted August 25, 2010 Report Posted August 25, 2010 Knew it was the bulbs lol yeah they were prolly old bulbs and the subs prolly rattled them loose. Easy fix =] Quote Audio Technix Online Customer Service Specialist [email protected]
