Hey guys I just got my new HID light kit and im gonna put it in tomorrow but all the websites say you need a relay off the battery to make it work right or you will burn up your factory switch and fuses. My question is why are they plug and play if that could occur should I be concerned about this or am I worrying over nothing. Car is in sig and the hid kit is a 35w 6k h11 bulb type for my low beam.
edit spelling
Edited by Jville140db
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
35w ballast will be fine to plug and play. 55w ballast can draw a lot more current and cause damage or not even work with factory wiring which is when you would need a relay wiring harness but you're good to go with 35w
cool im gonna do the relay harness on my high beams when i do my 4300 or 5000 55 watt kit but i didnt wanna screw up my new car its already been through the wringer as it is
Currently in car
you usually need relays on older cars like 1980 's and all that were u can burn up the fuse etc. but i did a 02 yukon with 55 watts on both highs and lows and 35 watts on fogs and havent had any problems at all no relays just plug and play its been 4 months already
Edited by jl_audio
i figured a 2010 tc would be cool but i just wanted to ask
Currently in car
yeah i figuered u should be alright since ur stock halogen draws 55 watts
yeah my concern came when they said that they spike when first turned on at 12-15 amps and my stock fuses are only 10 for each lamp
Currently in car
I've never had this sort of issue and I've done lots of hid kits. But all have been 35 watt kits. I think you're going to be fine.
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
