ADVISE ON AIR BAGS KITS OR SUSPENSION
hello everyone, my name is kevin and i have a quick air bag question. I am not to knowledge able about air suspension kits so bear with me please. I have a 2006 Escalade and i want to put 28's on it, so i thought about goin the air suspension and air bag route. what are some good air bag kits that come with everything you need to accomplish the task and be quality as well. and how much do you think its gonna cost? I just want my caddy to look SICK! thanks for your time.
Pics of vehicle and you'll get a lot more help...
Airbaggit.com, Airridetechnologies.com. There are several ways to go about it... Whats your goal with this, lay frame, tuck wheels?
I appreciate your response, ill get pics on here soon as i can , im at work right now- I under stand there are several ways to go about it and with that being said i would like to have a nice smooth ride and when i wanted to show it off i wanted the wheels to tuck when i dropped it down.
I dont recommend airbigit.com at all i got my kit from them and it leaks
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
your particular goal is HUGE. if you want it to be low on 28's then like someone said, it's going to take alot of custom and very expensive work. just a little thing to go by, your average GOOD custom car shop who can do that job right will charge at least $60/hr and all the way up to $120/hr depending on where you go and how nice you want it to be
THIS^^^^
That doesnt have anything to do with the company, that has to do with the install...
#1 Use teflon tape.
#2 Blow out airline and valves before hooking up. ( This ensure that there isnt any trapped stuff that can cause leaks)
I purchased the plug and play kit. so i had to put nothing together. just plug in air hoses. it came with some cheap plug to insert the air hose that kept blowing off and i had to go out and purchase compression fittings witch the kit should have came with. Just my personal exsperince with them.
Whatever you do stay away from AIR BAG IT !
all of these are my .02
Use Viair compressor , Slam Specialties or Airlift dominator bags ( NOT DEnominator from airbagit)
SMC valves,asco,airlift, or parker valves .
Check out suicidedoors.com , way layed inc , there are a few others..
Whatever you do STAY AWAY FROM AIRBAGIT.COM and ALL of the sister companies.
I guess im not the only one huh
i say build your own brackets. cut your arms and notch your frame. do it right don't plug and play. don't pay and wait. look up some drop parts you need and modify them or build what you have to out of plate steel.
air struts are for little bit of play not laying out. tucking more than 2inches of 28's will require fabricating and real bags :) Just Do It :drinks:
JVC AVX-44 and 360.2
Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port
Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2
Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
  • Who's Online   0 Members, 0 Anonymous, 1261 Guests (See full list)
