Impact driver. And hitting the head won't do sh!t except mess the bolt up, impact drivers don't work by vibration ;/
If the hex-head doesn't fit perfectly then make sure it's not a metric size. Depending where the woofer was made it may well be.
10.x volts fo' life!
2x on impact driver.
Hammerdown... 1%
just expect the bolts to be broken when your done. they make an impact Screwdriver, handheld, and the heads will break right off..
so be prepared because you will be drilling those bitches out.
or you could use acetone and let it soak and break the superglue holding the screws in. lol..
this is spam imo, its not allowed here
i've never broken one with an impact driver.
Hammerdown... 1%
are you sure its a hex head and not a torques head? also... heat is your friend... put a good soldering iron on the head of the bolt for about a minute or so... get it good and hot, the glue should soften up enough to let it turn
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Alright, thanks on all the advice guys, but I got them out finally. Now, the motor and basket still won't separate, can't even find the spot where they separate, its like 1 whole piece lol..HELP?
Are they glued together? Torch doesn't seem to be working, lol.
Edited by Slawsen
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
what kind of sub is it?
there baskets are usually glued to the motor too, ive had luck with just a flat head screw driver
06 kicker L7 and im about to post pics, but how the hell do i get rid of the glue? acetone?
pics
00' Nissan Xterra
  • Who's Online   2 Members, 0 Anonymous, 1075 Guests (See full list)
