Ignition and Accessory Wires in Alarm Harness Help.
so i recently got my viper 5701 in the mail today. Ilovetoinstall on here gave me an awesome wiring diagram that says the following (not all of it, only part):
12 Volts- white(+) ignition harness
Starter- black/white (+) ignition harness
Ignition- black/yellow (+) ignition harness
Second Ignition- black/orange (+) ignition harness
Accessory- blue/red (+) ignition harness
now i go on the12volt.com and this is what it says
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Orange Ignition Switch Harness
Accessory Black/Yellow Ignition Switch Harness
now the diagram i got from ilovetoinstall says that the ignition wire is black/yellow and accessory is blue/red. yet on the12volt's diagram, ignition is black/yellow and accessory is black/orange. also the second ignition wire on ILTI's diagram is listed as a regular ignition wire on the the12volt diagram.
can anyone give me some clarification on this? its a 1994 corolla
multimeter them. you should test them to begin with.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Accessory would show 12v+ when key is turned to ACC correct? and Ignition would show 12v with the key in the ON position (car not on)? but how would i test to find the second ignition wire?
im very rusty on my alarms but it tests the same way. I'm pretty certain you dont have to connect it but if you try to remote start without it the blower motor and stuff like that wont engage. I honestly cant remember now.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
hmm. is there anyone you recommend me talking to? i would like to stay away from shops since i do not trust anyone with my car. i have installed everything myself so car and i'd like to keep it that way.
check with shyne 151 or Ray on here . they do 15 a day.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Here you go, always probe before connections... Igntion wires will show 12v at accessory, crank, and run... Accessory will show 12v at accessory and run..
And here is your ign wires:
12 Volts white + ignition harness
Second 12 Volts
Starter black/white + ignition harness
Second Starter
Ignition black/yellow + ignition harness
Second Ignition black/orange + ignition harness
Third Ignition
Accessory blue/red + ignition harness
Pretty coherent for being drunk at the bar on an iPhone ;)
-Installer for Duke's Car Stereo
2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
RF Punch 6.5" components and MB Quart Premium 6x9"s
Powermaster Alternator, YellowTop D34, Vmax CT1000
Second 12 Volts
Second Starter
Third Ignition
LOL thanks a lot man. one more question regarding parking lights. this viper brain only has 1 wire for a parking light. you can switch it from + and - with a 10 amp fuse (says to use - if lights pull over 10 amps). how would i know which wire to use in my car if theres only 1 wire on the brain?
  • Who's Online   1 Member, 0 Anonymous, 1705 Guests (See full list)
