MarioB Posted September 21, 2010 Report Posted September 21, 2010 what do you guys think of a bandpass box? ive been talking to Kicker Tech. and hes recommending i build a bandpass box for my Solo X with the port firing into the car. he said it should be louder than the ported box i currently have firing into the car. any thoughts? 12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodcsoundlab.com Quality is all in how you take pictures I have plenty of projects that look WAY better on camera then in person crazy to fit so many in so little. Reminds me of some of the porns I've seen?
Hugh G. Rection Posted September 21, 2010 Report Posted September 21, 2010 what do you guys think of a bandpass box? ive been talking to Kicker Tech. and hes recommending i build a bandpass box for my Solo X with the port firing into the car. he said it should be louder than the ported box i currently have firing into the car. any thoughts? are you dealing with jeremy at kicker? Owner of BigAss Ports
MarioB Posted September 21, 2010 Author Report Posted September 21, 2010 are you dealing with jeremy at kicker? No its not jeremy i forget his name off top of my head? 12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodcsoundlab.com Quality is all in how you take pictures I have plenty of projects that look WAY better on camera then in person crazy to fit so many in so little. Reminds me of some of the porns I've seen?
S Dime 420 Posted September 21, 2010 Report Posted September 21, 2010 Bandpass = FTL. If anybody in the Sacramento area has a vehicle for sale for less than $1,500 get at me. I'm open to almost anything that runs.
uhoh_45 Posted September 21, 2010 Report Posted September 21, 2010 Bandpass = FTL. ????????? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
OldsBoomer Posted September 21, 2010 Report Posted September 21, 2010 Bandpass = FTL. you want to explain your answer? Suburban Coming Soon
TimberWolf Posted September 21, 2010 Report Posted September 21, 2010 I have a Memphis 12" in a single bandpass and the only thing I can complain about is that the plexi front was too thin. I think if you have room for a decent bandpass then do it. I plan to build a triple bandpass after the first of the year. I just need a design that uses a rectangle port. if anyone has ideas the subs need 1.5cu.ft. each.
MarioB Posted September 21, 2010 Author Report Posted September 21, 2010 I have a Memphis 12" in a single bandpass and the only thing I can complain about is that the plexi front was too thin. I think if you have room for a decent bandpass then do it. I plan to build a triple bandpass after the first of the year. I just need a design that uses a rectangle port. if anyone has ideas the subs need 1.5cu.ft. each. Heres the specs i was given 1.5cu. ft sealed side (per sub).....4.5cu. ft (total for both subs) ported area.....80" sq opening for the port that is 10.5" deep into the box, tunes @56Hz with a band width of 43- 71Hz. 12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodcsoundlab.com Quality is all in how you take pictures I have plenty of projects that look WAY better on camera then in person crazy to fit so many in so little. Reminds me of some of the porns I've seen?
Boon Posted September 22, 2010 Report Posted September 22, 2010 Sounds pretty good to me 10.x volts fo' life!
