So i was bored and felt like learning the tricks of the Google Sketch up trade. Heres a box i made for 4 15's.
4 ft wide, 2 ft deep, 4ft tall
Front view
Each sub has its own "Chamber" separated by a divider.J shaped outlets coming from port divided to each side then to top and bottom.
Any other ideas for boxes would be appreciated.
2005 Chevy Silverado z71 crew cab.
DD2515a 2ohm
Lunar 1500w
JVC head unit
"My beat quakin mirrors shakin"
theres no depth to the walls?
Try drawing the bottom wall. use the push/pull tool to drag it up to thickness (type in 3/4 and hit enter after you start dragging) then take the measuring tool and line drawing tool to draw out how the walls are gonna look (the inside of them, the outside lines will be the edges of your bottom piece). Then once you got that laid out, use the push/pull tool again to drag the walls straight up to the desired height.
Question, how did you do the see through thing? Also would this box design be fuctionable?
DD2515a 2ohm
Lunar 1500w
JVC head unit
damn man
i still cant figure out google sketch <_<
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
it will work but not great
no tuning at all, no attention to anythign to do with box design theory whatsoever
damn man
i cant figure it out either. i just go straight to rhino and im covered on 3d modeling.
video using rhino on my enclosure -http://www.youtube.com/watch?v=udlM2izCaTE
Owner of BigAss Ports
Im trying to learn the art of box tuning.
DD2515a 2ohm
Lunar 1500w
JVC head unit
its not that bad. there are lots of good free box calculators out there. ive been trying to learn the bandpass game myself......
