So i was bored and felt like learning the tricks of the Google Sketch up trade. Heres a box i made for 4 15's.
4 ft wide, 2 ft deep, 4ft tall
Front view
Each sub has its own "Chamber" separated by a divider.J shaped outlets coming from port divided to each side then to top and bottom.
Any other ideas for boxes would be appreciated.
2005 Chevy Silverado z71 crew cab.
DD2515a 2ohm
Lunar 1500w
JVC head unit
"My beat quakin mirrors shakin"
theres no depth to the walls?
Try drawing the bottom wall. use the push/pull tool to drag it up to thickness (type in 3/4 and hit enter after you start dragging) then take the measuring tool and line drawing tool to draw out how the walls are gonna look (the inside of them, the outside lines will be the edges of your bottom piece). Then once you got that laid out, use the push/pull tool again to drag the walls straight up to the desired height.
damn man
i still cant figure out google sketch <_<
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
  • Who's Online   0 Members, 0 Anonymous, 1705 Guests (See full list)
