If the DCR is 1.7, they are not 1.4 coils. . . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Simply assume they are 2 ohms for this exercise.
Wire to 4 ohm each woofer than all in parallel for 1.33 -- each amp will see 0.67
Right, so if they are 1.4, the amps would see .46 each. Should be okay after rise, right?
Edit: I think i'm finally catching on to the whole Ohm's Law thing.
Edited by OrionStang
SMD Super Seller
My Feedback Thread
yeah i wouldn't have someone assume such things...
ok here's your options, i'll make it easy for you.
each coil is 1.4.
1.4 x 2 = 2.8 per speaker when wired in series
1.4 \ 2 - .7 per speaker when wired in paralell.
ok now we treat each DVC sub as SVC subs with either 2.8 load or 0.7 load
0.7 x 3 = 2.1
0.7 / 3 = 0.233333 eww.
2.8 x 3 = 8.4
2.8 / 3 = 0.93333
ok now we got 4 optional loads to be split between 2 amps strapped.
2.1 / 2 = 1.05
0.2333 /2 = .. yeah we won't go there..
8.4 / 2 = 4.2 not gonna see a lotta power here...
0.933333 / 2 = 0.4666666 we can call this 0.5 per amp..
SO there's 2 viable choices here.
each sub in series with itself and parallel with the other 2 subs for a final load of 0.46666 per amp.
or
each sub parallel with itself and series with the other 2 subs for a final load of 1.05 per amp.
Thats pretty much dummy proof. Thanks, i'm learning it. I think Jacob was just trying to make it easy for me.
You know... you are right... you probably know more about how to wire the amps than me :drink40:
Thank you.
SMD Super Seller
My Feedback Thread
... and since I was just joking above ... I will repeat :)
A 1.4 DCR coil is 2 ohms nominal... you can assume it is a 2 ohm for wiring your amp.
An amp designed for 1 ohm will handle a 0.7 DCR load -- it's taken into account. Same goes for wiring numerous woofers together... I've tested it and I've wired up a "few" of our amps over the years to 0.7 / 1.4 DCR woofers (1 ohm and 2 ohm nominal respectively).
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
Man Sundownz, we posted the same thing. . .does not matter how many times it gets posted, people just don't understand the 1.4 ohms DCR vs. 2 ohms nominal AC impedance. . .
Current system:
Previous systems:
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
