SnowDrifter Posted November 7, 2010 Report Posted November 7, 2010 As the title suggests... Do I need to use the stud for additional bracing on the AA SMD if I do horizontal (forward facing) mounting? Can I get by without it by just using bigger / longer screws and a thicker front baffle? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Alex K Posted November 7, 2010 Report Posted November 7, 2010 As the title suggests... Do I need to use the stud for additional bracing on the AA SMD if I do horizontal (forward facing) mounting? Can I get by without it by just using bigger / longer screws and a thicker front baffle? You don't need to use it. But imagine holding the sub by just the basket out in front of you, sub facing you. Now imagine you holding the sub same way, but you're resting the stud on a surface. What's easier? As long as the baffle can hold it, and you use some beefy screws it should be fine. My lvl 5 is mounted horizontal and it's doin fine. I think trippi has all 6 of his just being held by screws iirc. 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
jeyrapboy Posted November 7, 2010 Report Posted November 7, 2010 ^^^^ Well his are mounted subs up so that is vertical not horizontal.
SnowDrifter Posted November 7, 2010 Author Report Posted November 7, 2010 You don't need to use it. But imagine holding the sub by just the basket out in front of you, sub facing you. Now imagine you holding the sub same way, but you're resting the stud on a surface. What's easier? As long as the baffle can hold it, and you use some beefy screws it should be fine. My lvl 5 is mounted horizontal and it's doin fine. I think trippi has all 6 of his just being held by screws iirc. I was wondering if I could get away with it. Adding a brace to bolt in the stud adds another level complexity that I would rather not deal with ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
ChevyBoy95 Posted November 7, 2010 Report Posted November 7, 2010 Trippis wall has them horizontal... 99% sure Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
siccostyle Posted November 7, 2010 Report Posted November 7, 2010 Vertical is up and down, horizontal is side to side. wall = horizontal. Trippi has a wall. That would be horizontal and he is not using regular screws he is using a heavy duty 3" lag screws/bolt (look up Trippis hummer in the members build section) Edit= what is in Trippis hummer 01 2dr ExploderBuild log2 18" DC Level 6's (M3's)DC 10k5 XS d3100's, DC 390 alt100' shok ofc cable Team ShokTEAM SUB SONIC ADDICTION
