if you want to get firewall so u can use it on both cars then sure why not. but if your only putting something on the metal roof of the car then a mat product vs the liquid would be much easier.
Just think of it like painting the roof of a house. you have to tarp everything off do multiple layers and wait inbetween. damp pro is simple prep the surface and stick it on
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
I dont know about defining, hehe maybe by not getting my fingers all cut up and getting into tighter spots =). The main reason I wanted to get firewall was to use some of it in my 86 300zx transmission tunnel as well. It gets up to 110 degree surface temps on the tunnel and makes crusin a nice day of 76 degrees hot and I have to turn on the AC.
I was reading and I think it was 2 layers is 2mm 80mls. That was according to the website, and DP is 2mm.
Not in thickness, but in performance. Your gonna need more sludge thickness than dp for the same performance.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
But wouldnt the mat not work against the heat like Id want it?
wow really, according to them they said its the same and performs just as good at 2mm thick.
damp pro does work against heat but not as well as firewall. it does work better then firewall as far as vibration dampening.
if your looking for only heat then yes firewall or the thermal block would be my choice. if you need vibration dampening as well then id say something like 4 sheets of damp pro and firewall from there.... its just going to suck to put firewall on ur roof
take a look at sounddeadenershowdown.com and talk to Don : he's a cool guy, very very knowledgeable on deadening. He has tested quite all the different products on the market, and now make his own. Good price too.
But Secondskin is really good; easy to apply, no smell, and hold for long !
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
But with it reflecting heat it just distributes it but it will eventually get hot?
...Im glad I asked questions here first before I bought stuff.
well ya... Damp pro is mainly meant for vibration and firewall is mainly meant for heat. Both have some of the other effect but its really the best idea to buy either or depending on what you want and if you want both then use a combo of both
I been lurking on these forums for sometime. I have calculated costs of doing my car in damplifier pro and in spectrum and found spectrum to be cheaper.
I see peoples builds and people doing their doors and headliner with DP but wont it be easier to just use spectrum?
Awsome site btw
You could use Spectrum or Firewall and then a layer of Heat Wave or Heat Wave Pro. But, you will have to wait 30 days for them to fully cure before applying the HW.
Or, you could install Damplifier or Damplifier Pro and then Heat Wave or Heat Wave Pro. With this method, you won't have to wait for a cure time and you'll have a nice sound and thermal barrier.
Or, you could paint your roof white and stop alot of heat from ever reaching the inside of the vehicle..... :good:
Hope that helps!
Ken
Hope that helps!
Ken
sorry Ken i just realized you didnt have your "partner" tags! I just fixed it! good to see you on the board! :):drink40:
Follow my Tweet (Twitter)
