Farmacist Posted November 17, 2010 Report Share Posted November 17, 2010 Right now I'm currently have 2 different routers, The first is a 1/4 collet ryobi, and the other is a Crasftmen professional 1/2hp 1/2 collet router. The bits I use for making ring baffles are 1/4 straight shaft... is there something better to use? I've been noticing that sometimes theres like a mm difference when I'm going cutting around the circle, and setting the depth lower, has anyone has this before? I know I'm not going too fast.. This occurs when I use both routers, and the only thing i could think of is that its either the Jasper 200 jig I'm using, or its the type of bit. Team Soundstream Team Xs Power Team Secondskin Audio Team Mechman Link to comment Share on other sites More sharing options...
mbdblue Posted November 17, 2010 Report Share Posted November 17, 2010 Right now I'm currently have 2 different routers, The first is a 1/4 collet ryobi, and the other is a Crasftmen professional 1/2hp 1/2 collet router. The bits I use for making ring baffles are 1/4 straight shaft... is there something better to use? I've been noticing that sometimes theres like a mm difference when I'm going cutting around the circle, and setting the depth lower, has anyone has this before? I know I'm not going too fast.. This occurs when I use both routers, and the only thing i could think of is that its either the Jasper 200 jig I'm using, or its the type of bit. I think it could be the jasper without question...I noticed that those holes to mount it on the router arent cut out to be perfect for those bolts. there is a small amount of play (probably only 1/16th of an inch) in it that could change the diameter. I believe this is due to the fact that the jasper isnt made for one specific router. so whenever I mount my jasper on, I try and get as close to the middle of each hole as possible before putting the bolts in. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
Farmacist Posted November 17, 2010 Author Report Share Posted November 17, 2010 this helps describe what I'm talking about I can't stand it Team Soundstream Team Xs Power Team Secondskin Audio Team Mechman Link to comment Share on other sites More sharing options...
cOmpressor Posted November 17, 2010 Report Share Posted November 17, 2010 Use a longer spiral cut bit, upcut or downcut your choice. 100x easier to get right and cuts much faster. Link to comment Share on other sites More sharing options...
Soapbox Posted November 18, 2010 Report Share Posted November 18, 2010 Use a longer spiral cut bit, upcut or downcut your choice. 100x easier to get right and cuts much faster. Proper term is fluted to the right or left spiral cut bit TEAM FLEX ISSUES, TEAM DC AUDIO 2010 California State Finals Champion MECA AS2 2011 California State Champion Meca S2 2011 California State Record holder Meca S2 2012 Meca Mod 4 class 152.5 and rising Link to comment Share on other sites More sharing options...
mbdblue Posted November 18, 2010 Report Share Posted November 18, 2010 this helps describe what I'm talking about I can't stand it aaahhhh now I get what ya mean...yeah mine does that too. It dont really make a difference to me though. so I guess if you get a fluted bit, itll fix that problem soap? AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
Gotloud555 Posted December 6, 2010 Report Share Posted December 6, 2010 Get some sandin' papers and get the edges smooth.. Link to comment Share on other sites More sharing options...
