WaTTz305 Posted November 19, 2010 Report Posted November 19, 2010 as the title says. were looking to bag my friends 01 denali. thanks
kandiman71874 Posted November 19, 2010 Report Posted November 19, 2010 ummm, you remove them.... The torsion bar acts as a spring so once it is removed and the bags are installed, the bag does the job that the torsion bar did. Watch Steve's vid when they did his Tahoe, you'll get the point http://www.youtube.com/meade916#p/u/98/YrAJo-VopCo Daily Driver 1999 Kia Sephia Kenwood DNX-893s Audison Bit One Processor 2 Dat 4.125's Sundown Audio SCV-6k Hertz hsk-165xl's Mids running active Focal V30 Series Tweeters running active Sundown Sa-8 v1's in the doors 2 Sundown Zv5 12's Lots of Hushmat Big 3+ and 3 + & 3- runs of Trystar 2/0 2 Dc Power Engineering 320 HP Alts 2017 Comp Vehicle 2006 Toyota 4 Runner Kenwood Excelon DNX-893s Audison Bit One HD DSP 4 Sundown Sa 6.5v2 Component Sets Focal Access 6.5 2 ways Sundown Audio Sax-50.4 Sundown Audio Sax-100.4 2 Dc Power 370xp Northstar agm27f Northstar agm65 2 Northstar asmagm 480's 2 Dual 1 Sundown Nightshade v3 12's 2 Sundown SCV-7500's All SMD Fuse Holders Shitload Of Sundown 1/0 120 sq ft Second Skin Damp Pro No, Its Not A Burp Truck!!!! 2016 Season 3rd place in Xtreme 1 At Finals 2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations) 2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL David said: audio is a lifestyle, not a hobby newls1 I cant read a tape to save my life... 1/2's are ok, but other marks confuse me kingsuv only men who cant read a tape, take it in the ass kingsuv you sir, get a pink hard hat on jobsites
superdave07 Posted November 20, 2010 Report Posted November 20, 2010 ^^^^^ this. my hard body had torsion bar front end. removing them is the easiest way... Xterra * 69 Camaro * Audi S5 36 Ford * 51 Mercury looking for wire sponsor www.flyracing.com
badcayne Posted December 27, 2010 Report Posted December 27, 2010 yeah you gotta remove the torsion bars, BUT since the denali is an AWD not a 4wd you cant remove the front axles,so you have to make a custom tower above the upper control arm to mount the bags and also use tubular upper arms.or pu.l the entire AWD setup(front diff,transfer case and transmission) and install a regular 2wd transmission and mount the bags on the lower control arms. this is a pic of an escalade,same AWD setup. http://i174.photobucket.com/albums/w109/nyccustomizer/whiteescalade085.jpg
Ford302Redneck Posted December 27, 2010 Report Posted December 27, 2010 yeah you gotta remove the torsion bars, BUT since the denali is an AWD not a 4wd you cant remove the front axles,so you have to make a custom tower above the upper control arm to mount the bags and also use tubular upper arms.or pu.l the entire AWD setup(front diff,transfer case and transmission) and install a regular 2wd transmission and mount the bags on the lower control arms. this is a pic of an escalade,same AWD setup. http://i174.photobucket.com/albums/w109/nyccustomizer/whiteescalade085.jpg You make it sound a little harder than it is. Most transmisson has bolt on tailshafts so therefore doesn't have to replace the whole transmisson is he went that route. You could leave everything, just take out the drive shafts and axle shafts. Leaving the differential and transfer case won't matter much. And just incase he wanted to go back it would be there.
korey_hofer Posted December 27, 2010 Report Posted December 27, 2010 yeah you gotta remove the torsion bars, BUT since the denali is an AWD not a 4wd you cant remove the front axles,so you have to make a custom tower above the upper control arm to mount the bags and also use tubular upper arms.or pu.l the entire AWD setup(front diff,transfer case and transmission) and install a regular 2wd transmission and mount the bags on the lower control arms. this is a pic of an escalade,same AWD setup. http://i174.photobucket.com/albums/w109/nyccustomizer/whiteescalade085.jpg You make it sound a little harder than it is. Most transmisson has bolt on tailshafts so therefore doesn't have to replace the whole transmisson is he went that route. You could leave everything, just take out the drive shafts and axle shafts. Leaving the differential and transfer case won't matter much. And just incase he wanted to go back it would be there. you have no idea how that awd system works, you can not just pull the axle shafts out in a Denali and call it good previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Ford302Redneck Posted December 27, 2010 Report Posted December 27, 2010 yeah you gotta remove the torsion bars, BUT since the denali is an AWD not a 4wd you cant remove the front axles,so you have to make a custom tower above the upper control arm to mount the bags and also use tubular upper arms.or pu.l the entire AWD setup(front diff,transfer case and transmission) and install a regular 2wd transmission and mount the bags on the lower control arms. this is a pic of an escalade,same AWD setup. http://i174.photobucket.com/albums/w109/nyccustomizer/whiteescalade085.jpg You make it sound a little harder than it is. Most transmisson has bolt on tailshafts so therefore doesn't have to replace the whole transmisson is he went that route. You could leave everything, just take out the drive shafts and axle shafts. Leaving the differential and transfer case won't matter much. And just incase he wanted to go back it would be there. you have no idea how that awd system works, you can not just pull the axle shafts out in a Denali and call it good Most AWD works when its needed it comes on. Correct? I said driveshalfs and axles. I mean I know this isn't the 100% right thing to do but I'm sure it could work. And I'm sure, you can cut off whatever turns off/on the transfer case to ever engage. Maybe I'm wrong? Just a thought.
meade916 Posted December 27, 2010 Report Posted December 27, 2010 yeah you gotta remove the torsion bars, BUT since the denali is an AWD not a 4wd you cant remove the front axles,so you have to make a custom tower above the upper control arm to mount the bags and also use tubular upper arms.or pu.l the entire AWD setup(front diff,transfer case and transmission) and install a regular 2wd transmission and mount the bags on the lower control arms. this is a pic of an escalade,same AWD setup. http://i174.photobucket.com/albums/w109/nyccustomizer/whiteescalade085.jpg You make it sound a little harder than it is. Most transmisson has bolt on tailshafts so therefore doesn't have to replace the whole transmisson is he went that route. You could leave everything, just take out the drive shafts and axle shafts. Leaving the differential and transfer case won't matter much. And just incase he wanted to go back it would be there. you have no idea how that awd system works, you can not just pull the axle shafts out in a Denali and call it good actually, you can. Chickens 02 Caddy (the hoopty) has had the AWD removed from it since day 1 (to make room for bags) All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
meade916 Posted December 27, 2010 Report Posted December 27, 2010 as for the torsion bars, if you bag, take them out...... All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
korey_hofer Posted December 28, 2010 Report Posted December 28, 2010 yeah you gotta remove the torsion bars, BUT since the denali is an AWD not a 4wd you cant remove the front axles,so you have to make a custom tower above the upper control arm to mount the bags and also use tubular upper arms.or pu.l the entire AWD setup(front diff,transfer case and transmission) and install a regular 2wd transmission and mount the bags on the lower control arms. this is a pic of an escalade,same AWD setup. http://i174.photobucket.com/albums/w109/nyccustomizer/whiteescalade085.jpg You make it sound a little harder than it is. Most transmisson has bolt on tailshafts so therefore doesn't have to replace the whole transmisson is he went that route. You could leave everything, just take out the drive shafts and axle shafts. Leaving the differential and transfer case won't matter much. And just incase he wanted to go back it would be there. you have no idea how that awd system works, you can not just pull the axle shafts out in a Denali and call it good actually, you can. Chickens 02 Caddy (the hoopty) has had the AWD removed from it since day 1 (to make room for bags) they took it out right not just pulled the axles out, you pull the axles and the front diff drains and gets fluid all over and if it isn't disconnected from tcase it would still be spinning which would burn it up. I hate the awd systems on the caddy and denali wish they used the same system as the tahoe and youkon, well I guess that is all if it was the same as the one I help replace a broken axle shaft on but it was older previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
