how do you bag with torsion bars?
ummm, you remove them....
The torsion bar acts as a spring so once it is removed and the bags are installed, the bag does the job that the torsion bar did.
Watch Steve's vid when they did his Tahoe, you'll get the point http://www.youtube.com/meade916#p/u/98/YrAJo-VopCo
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
^^^^^ this. my hard body had torsion bar front end. removing them is the easiest way...
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
  • 1 month later...
yeah you gotta remove the torsion bars, BUT since the denali is an AWD not a 4wd you cant remove the front axles,so you have to make a custom tower above the upper control arm to mount the bags and also use tubular upper arms.or pu.l the entire AWD setup(front diff,transfer case and transmission) and install a regular 2wd transmission and mount the bags on the lower control arms.
this is a pic of an escalade,same AWD setup.
http://i174.photobucket.com/albums/w109/nyccustomizer/whiteescalade085.jpg
You make it sound a little harder than it is. Most transmisson has bolt on tailshafts so therefore doesn't have to replace the whole transmisson is he went that route.
You could leave everything, just take out the drive shafts and axle shafts. Leaving the differential and transfer case won't matter much. And just incase he wanted to go back it would be there.
you have no idea how that awd system works, you can not just pull the axle shafts out in a Denali and call it good
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Most AWD works when its needed it comes on. Correct?
I said driveshalfs and axles. I mean I know this isn't the 100% right thing to do but I'm sure it could work. And I'm sure, you can cut off whatever turns off/on the transfer case to ever engage.
Maybe I'm wrong? Just a thought.
actually, you can. Chickens 02 Caddy (the hoopty) has had the AWD removed from it since day 1 (to make room for bags)
Follow my Tweet (Twitter)
as for the torsion bars, if you bag, take them out...... :werd_msword:
they took it out right not just pulled the axles out, you pull the axles and the front diff drains and gets fluid all over and if it isn't disconnected from tcase it would still be spinning which would burn it up. I hate the awd systems on the caddy and denali wish they used the same system as the tahoe and youkon, well I guess that is all if it was the same as the one I help replace a broken axle shaft on but it was older
  • Who's Online   1 Member, 0 Anonymous, 1610 Guests (See full list)
