KnockinthaStreetzof608 Posted November 27, 2010 Report Share Posted November 27, 2010 to make a 1.5 round over on a front of a port?? CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
kirill007 Posted November 27, 2010 Report Share Posted November 27, 2010 Try searching for 1.5 inch roundoverbit. >< It's not that hard, it's called GOOGLE. Thinking is the root of all problems... You ALWAYS get what you pay for. Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted November 27, 2010 Report Share Posted November 27, 2010 Freud Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
Z71 Thumper Posted December 9, 2010 Report Share Posted December 9, 2010 I hAve a craftsman router n I want to make 6.5 an 15" ring flush how do I go about doing that whAt type of bit n measurements should I do <script language='JavaScript' src='http://www.rockfordfosgate.com/downloads/banner_link.asp?p_id=18'></script> Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted December 9, 2010 Report Share Posted December 9, 2010 I hAve a craftsman router n I want to make 6.5 an 15" ring flush how do I go about doing that whAt type of bit n measurements should I do If I understand correctly you want to make a few flush rings? You're gonna need a 1/4" flute spiral upcut bit and to make some measurements of cutout diameter, basket depth, and basket width. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
kingsuv Posted December 9, 2010 Report Share Posted December 9, 2010 There is a couple different ways you can make flush mount rings. The easiest way with subs id to double stack your wood. Drill out your center point then cut each ring separately to the size you need, then re-stack the 2 sheets. For speakers, it can be a little more tricky. One way is to make the pass the depth of the flush and then cut your outside and inside hole sizes. Or you can use a rabbit bit to make the the step for the speaker I prefer to use a downward sprial cut but for speaker hole because it will throw your cutoff into the box and not back up in your face. I then like to use an up cut bit when the router is in the table to help suck the piece I am cutting to the table. Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it. Link to comment Share on other sites More sharing options...
Z71 Thumper Posted December 11, 2010 Report Share Posted December 11, 2010 Ok cool thAnks guys and if I have the Jasper how should I go about it it's my first time using it do u guys also a good place to purchase mdf wood <script language='JavaScript' src='http://www.rockfordfosgate.com/downloads/banner_link.asp?p_id=18'></script> Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted December 14, 2010 Report Share Posted December 14, 2010 Ok cool thAnks guys and if I have the Jasper how should I go about it it's my first time using it do u guys also a good place to purchase mdf wood Check around either Home Depot or Lowes, or look for a lumber yard in the yellow pages sometimes they have much better wood at much better prices. And the Jasper 200 is pretty simple, screw it onto the bottom of your router put a 1/4 inch bit in it, drill a hole at the center of where you want the circle to be and put the pin in the jig at the size you need and then into the hole...then route it out. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
