i cant believe you were running 8 gauge power wire on that amp.
8 gauge ground and 4 gauge power i know ive been meaning to upgrade that for along time
lmao i was just messin wit ya, thats the same way i fried one of my amps. trial and error
good thing is we learn from our mistakes
yea big three upgrade in 1/0 and a second battery ran in parallel with 1/0 to the back battery with a good fuse inbetween the power
and 1/0 to the amp power AND ground with a good clean ground and a the right size fuse inbetween the amp and battery with i think would be 200 amp
the 2200d is fully stable to 1 ohm i wouldnt run it a .5 unless i had VERY good electrical
if it were me id run it at two ohms or recone to D2 and wire it down to 1 ohm but its your choice
hit up knukonceptz for some 1/0 wire and darvex for terminals and fuse holders
ok i will check those companys out for the wire and fuse blocks and terminals
Currently in a build
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
Pioneer AVH-P2300 (next purchase)
High output alt 150 amps
holy fuck. 05 ohm and a 4 gauge power 8 gauge ground
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
