Soundigital 8000
bedmakerjj
Does anyone know if the SD8000 can play at .5 ohms without any issues
2002 Mitsubishi Lancer
3-18" Mayhem Subs
Pioneer AVH-6300BT
1-10K DC Audio Amplifier
1-5K DC Audio Amplifier
3-Pioneer GM-D9500
6-Kinetik HC2400
2-XS Power D3100
1-Kinetik HC1400
Ohio Gen 160-180 amp HO Alternator
probley but i dont see why you would want to?if you want more power go with the 12k one.
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
No they will not I've talked to murilo about that and they really don't like being played below 1 ohm. I'd go with a 12kd
Team Bass-Hz
Thanks for the responses
3-18" Mayhem Subs
Pioneer AVH-6300BT
3-Pioneer GM-D9500
6-Kinetik HC2400
2-XS Power D3100
1-Kinetik HC1400
Whats with everyones obsession with running low ohm loads, the SD8000 does over rated at 12 volts at 1 ohm, so if you can give it the power it needs even if you have a good amount of rise you will still likely see over rated power at 14-15volts constant.
¿ǝɯɐƃ ǝɥʇ
Murilo said they shouldn´t play under 0.7 ohms for daily and 0.5 for burps if i remember correctly, a buddy of mine played with it @ 0.33 ohms for burps and worked great , but said all that, i wouldn´t play it under 1 ohm, what for? it´s a monster amp at 1 ohm already :)
Just don't run it below 1 ohm, it's a amp that will deliver the power at 1 ohm and it wouldn't actually benefit by going below 1 ohm. ;)
why say probably if you don't know for sure? going off this post alone he could have shelled out loads of cash for an amp just to break it. when it in fact is not recommended to play that low (just as everyone else said). just curious...
although i'm also wondering why you'd want to go that low on such a big amp?
The reason i was wondering is because we had the subs already and it somehow slipped through the cracks when we were ordering the amps so now we have the SD 8000 never used yet and realized that the 4 subs we have are dual 2ohm so if we were to hook up the subs 2 per amp the amp will actaully be playing at .5ohms I know the amp is a big amp but a simple oversight was made when ordering so now just trying to figure out if amps could have still worked because they can't be returned
3-18" Mayhem Subs
Pioneer AVH-6300BT
3-Pioneer GM-D9500
6-Kinetik HC2400
2-XS Power D3100
1-Kinetik HC1400
  • Who's Online   0 Members, 0 Anonymous, 1094 Guests (See full list)
