STEvil Posted January 1, 2011 Report Posted January 1, 2011 no I'm not, I am who I am and no need to say it over and over again. you want to ride my ass you can find out for your self. Like I said 4 times now, I didn't want to get in a pissing match with you guys, you are the ones who wouldn't drop it. So stfu already and stop clogging the thread up already I found some 1/3 power numbers on caraudiomag.com; they measured 88%. If you dont want to say who you are you shouldnt say "all I'm going to do is laugh at you, you don't even know who I am. " MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Jagraj7870 Posted January 1, 2011 Author Report Posted January 1, 2011 Should I reopen up a thread because what I asked totally got ignored - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
korey_hofer Posted January 1, 2011 Report Posted January 1, 2011 you were told it would work already? previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
STEvil Posted January 1, 2011 Report Posted January 1, 2011 what question? I thought they were answered: Do not run your warhorse at 1 ohm, you need two dual 4's to get a 2 ohm load on the amp, nobody commented on the alternator because thats's a statement not a question and up to you. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Jagraj7870 Posted January 1, 2011 Author Report Posted January 1, 2011 Yah u guys clearified that, I was wondering if the alternator is a good idea, would u guys do that? - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
Jagraj7870 Posted January 1, 2011 Author Report Posted January 1, 2011 what question? I thought they were answered: Do not run your warhorse at 1 ohm, you need two dual 4's to get a 2 ohm load on the amp, nobody commented on the alternator because thats's a statement not a question and up to you. Also u can get 2 d1s because SMDs don't come in 4ohms - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
CJ18 Posted January 2, 2011 Report Posted January 2, 2011 Get as much alternator power as you can afford and fit. If you can afford dual alts then you NEED them. The higher you can keep your voltage, the more power you are going to see out of the amp.
hdorre Posted January 2, 2011 Report Posted January 2, 2011 The higher you can keep your voltage, the more power you are going to see out of the amp. I believe their limits are 15.5 volts though. Cody, I know what you meant though. You were talking about a 12volt electrical system (which shouldn't be charged over 14.8 volts). I just didn't want the OP to be confused if he doesn't have a lot of knowledge. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
CJ18 Posted January 2, 2011 Report Posted January 2, 2011 The higher you can keep your voltage, the more power you are going to see out of the amp. I believe their limits are 15.5 volts though. Cody, I know what you meant though. You were talking about a 12volt electrical system (which shouldn't be charged over 14.8 volts). I just didn't want the OP to be confused if he doesn't have a lot of knowledge. You are correct here. I keep mine charging at 14.9-15.1, just depends how the alt is feeling that day. I have a VCM on order to help control this better. As hdorre said before 15.5v is the shutoff point for the warhorse. I have also said this before in this thread but I will give you this info again. I have 8 XS D3400s, which give me 32000w in power handling. They are being charged currently by a mechman 270amp alternator (I have a new 350 amp unit ordered). At FULL TILT my voltage drops to 12.5 at the batteries and 12v at the amp. The closer you can keep your voltage to 14.4 the more power you will see.
Jagraj7870 Posted January 2, 2011 Author Report Posted January 2, 2011 okay so im designing my box and this is what i came up with thats my box design i want it to have red LEDs in it with smoked lexan thats what its tuned to how does this look? - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
