Mr.basshead Posted December 29, 2010 Author Report Posted December 29, 2010 Your ports are way, way too small. Go for ~3.5 cubes after displacement with 60^2" of port 18 inches long or 1 6" aero if you wanna smash the lows. 2 4" aeros on a 3515 is sacrilege, may as well put it in a prefab. Isn't one 6 inch aero pretty much the same amount of port area as 2 4's? 1 TC Sounds TC-3000 15 D2 (temporary until I get a box built for the both of them) Powerbass ASA 1500.1 Dx Pioneer Mvh-P8200 Soundstream MPQ-7XO 7 band Eq Crescendo CCX6.5's Rockford Fosgate Punch 200a4 C&D UPS490-MR in the back 2008 Kia Rio Lx
Boon Posted December 29, 2010 Report Posted December 29, 2010 Yes. But a 6" aero has a flare about the size of a 10" sub, and much less port wall per square inch. So it flows a LOT better. Circumference of 2x4" port = 25 inches Circumference of 6" port = 18 inches = much less friction. Port area isn't the whole equation. Laminar Flow is important - as you can see by the image here: Airflow is slowest along the surface and fastest in the middle. 10.x volts fo' life!
Mr.basshead Posted December 29, 2010 Author Report Posted December 29, 2010 So now my question is should I go with 3 4" aeros or 1 6"? 1 TC Sounds TC-3000 15 D2 (temporary until I get a box built for the both of them) Powerbass ASA 1500.1 Dx Pioneer Mvh-P8200 Soundstream MPQ-7XO 7 band Eq Crescendo CCX6.5's Rockford Fosgate Punch 200a4 C&D UPS490-MR in the back 2008 Kia Rio Lx
Boon Posted December 29, 2010 Report Posted December 29, 2010 I wouldn't compare anything less than 4 4" aeros to a 6" 10.x volts fo' life!
fecupe2001 Posted December 29, 2010 Report Posted December 29, 2010 i built a box for a 3515 and a DD m2 and that thing POUNDS!! i did 4.2 cubic feet and 72 SQ of port, for that sub, i would do AT LEAST a single 8" aeroport, 2 6´s should work great, 4-4.5 cubic feet should sound very good, you don´t have lots of power so it should ok I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
Joe X Posted January 26, 2012 Report Posted January 26, 2012 Full spec from DD, port size and all (huge box!): Series 3500e Voice Coil Diameter 3" Magnet Weight 240 oz Power Handling RMS/Peak 1200/4800 Suspension Travel 80 mm Nominal Impedance D.5, D1.0, D2.0, D4.0 Ohm Model 3515e Rec Box (cubic ft) 4.5 Port Area (sq in) 72 Port Length (inches) 19" Cutout Diameter (inches) 14.06" Mounting Depth (inches) 8.25" Free Air Resonance 33.65 Hz Qts .493 Qes .529 Qms 7.146 Vas 53.86 L Sensitivity 87.78 dB Shipping Weight 38 lbs
bassrace Posted January 26, 2012 Report Posted January 26, 2012 Whoa, talk about reviving the dead 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
Joe X Posted January 26, 2012 Report Posted January 26, 2012 I wouldn't compare anything less than 4 4" aeros to a 6" Friction losses are factored in the equation on which the Torres and other calculators are based so no need for additional considerations are necessary. And that's why you can't really replace two 4x4 vents with a 4x8 vent, the area is the same but losses are different.
TeamHT Posted January 26, 2012 Report Posted January 26, 2012 Welcome to tonight's late show! Featuring our first guest Joe X....... Tell me...does this smell like chloroform to you?
drbizerk Posted November 7, 2012 Report Posted November 7, 2012 i like how everyone likes to clown....joe x could have had some the insight that i was looking for. so what if the question was two years old! google "dd3515 box" (which is what i wanna find) and this thread pops up first page
