I'm just wondering if you wire one side of component set to one channel of an amp, 1 mid & 1 tweet thru the xover, will the channel still be @ 4ohms or does that drop it to 2ohms?
Also, what's some good 4ch amps that's are decent priced & do clean rated power? I was looking at the HiFonics ZXI8408... any suggestions are greatly appreciated!!!!
Edited by DreDay256
TEAM Fi CAR AUDIO/ TEAM CRESCENDO AUDIO
Bagged '06 Dodge Magnum R/T "WICKED WAYS"
-4 Fi SP4 18's (4th Order)
-2 Fi SSD 10's (midbass)
-4 Diamond Audio D6 Comp Sets
-1pr. Crescendo FT-1 Supertweets
-Dual Alts -6 XS Power Batts
-4 Crescendo BC3500d's (subs)
-1 Crescendo BC2000d (10's)
-1 Crescendo c1100.4 (comps)
It depends on the set. Each set will specify what the average impedance is at the crossover.
The AQ 4 channel isnt a bad priced amp in my opinion.
Eclipse cd7000
Ok. I'll check the owners manual to see if there's any info. Is there a general thumb on how many you can do on a channel?
I believe I seen the AQ 100.4 for like $375.. is that about right?
I'd try the cresendo 1000.4 if that's in your budget and won't overpower them
1998 Nissan 200sx
NOW:
Dex-p98r head
Planet Audio 300.4 mids and highs
Planet Audio/Pioneer tweeters/crossovers
Skar SK1500.1
3 SKAR Vvx15 dual 4 wired at .63
Anyone else???
Damn, no one owns component sets anymore???
Amazing..........................
Depends on the component set and how you run it. MOST 4 ohm component sets will have a crossover that shows a 4ohom load to the amp and then goes to the speakers from there.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
how else do you hook them up? other than bi amp or active, what you just described is the only way to hook components up. what ever the manual says the impedance is will be what your amp sees.
I must not understand your question or something.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Yea I don't think you understand.
I'm asking- if you wire one side of a comp set (1 mid & 1 tweet) to an amp, does the amp see 2 4ohm speakers or does it see the 2 speakers as 1 4ohm load?
