billy101 Posted January 6, 2011 Report Posted January 6, 2011 Hi everyone.. I got an Eclipse 3322 400 320watt amp in my 01 impala ls. It's being bridged to output 320 watts @ 4ohms. I have two 6 gauge runs of pos and negative from the battery to my trunk. At the battery, and the fuse holder it's reading 14.23 - .28 when the car is idling. When the car's idling, at the amp, it's only seeing about 12.3 steadily. Any reason why? Why am I losing 2 volts from the front to the back? First System 2002 Impala LS 3.8L V6, 128,365k miles. Alternator: DC Power 190Amp H/O Alternator Headunit: Kenwood KDC-BT945U. Speakers: MBQuart 6.5" Comps, 6x9 3-way. Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm. Box: 3.1cuft box tuned to 33hz. sealed off to cabin Big 3- done with all Knukonceptz KCA 0 gauge. Don't drop below 14.1v at full tilt.
STEvil Posted January 6, 2011 Report Posted January 6, 2011 because you ran a ground wire all the way from the battery probably. Shorten the ground so its only 1-2 feet long. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
tsuch20 Posted January 6, 2011 Report Posted January 6, 2011 upgrade your wire. 2011 Subaru WRX Rockford Fosgate T1000-4AD (2) Sets of Rockford Fosgate T3 6.5 Components In the works: Rockford Fosgate T2500-1bdcp (2)DC Audio 12" XLM2
billy101 Posted January 6, 2011 Author Report Posted January 6, 2011 because you ran a ground wire all the way from the battery probably. Shorten the ground so its only 1-2 feet long. Oh really? I really only ran the ground to the battery because its my first system and am unsure of where to ground to in the trunk. Would the bolt holding down my seatbelts work? First System 2002 Impala LS 3.8L V6, 128,365k miles. Alternator: DC Power 190Amp H/O Alternator Headunit: Kenwood KDC-BT945U. Speakers: MBQuart 6.5" Comps, 6x9 3-way. Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm. Box: 3.1cuft box tuned to 33hz. sealed off to cabin Big 3- done with all Knukonceptz KCA 0 gauge. Don't drop below 14.1v at full tilt.
jsawdy212 Posted January 6, 2011 Report Posted January 6, 2011 that could work but usualy those bolts are big. there may be a perfect size bolt on top of the shock tower if the car has struts. make sure u sand the paint around the area to bare metal too. 2007 caliber 2 Fi ssd 18's rd audio 3250 xs power d3100 (need 2 more) stock alt (soon to be singer 350a) 2.75:1 4th order in progress!
Autruche Posted January 6, 2011 Report Posted January 6, 2011 Don't use seat bolts or seatbelt bolts, they are crappy grounds. The best ground you can have is by drilling a hole through a good thick chunk of metal (not just sheet metal) and sanding down to bare metal and nut and bolt the ground there. Otherwise shock tower bolts work decent. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Rebel4055 Posted January 6, 2011 Report Posted January 6, 2011 Seat belt bolts are a NO NO! Ground to strut towers, grind the paint off before grounding there tho. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
billy101 Posted January 6, 2011 Author Report Posted January 6, 2011 that could work but usualy those bolts are big. there may be a perfect size bolt on top of the shock tower if the car has struts. make sure u sand the paint around the area to bare metal too. Alright, yes the car does have struts. They are easily accessable. I will see if I can use one of those tomorrow when I get home from school before I hook up my RE SRX12D2. Shortening the ground should most likely fix my voltage problem? @Rebel and guy above him.. Alright so nogo with the seat belt bolts. I will take everything out of the trunk and try and find a better place than the strut towers to ground to. If i sand off the paint, should I use one of those washers with the pointy spikes in it to "dig" into the metal? Would that be a secure ground? First System 2002 Impala LS 3.8L V6, 128,365k miles. Alternator: DC Power 190Amp H/O Alternator Headunit: Kenwood KDC-BT945U. Speakers: MBQuart 6.5" Comps, 6x9 3-way. Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm. Box: 3.1cuft box tuned to 33hz. sealed off to cabin Big 3- done with all Knukonceptz KCA 0 gauge. Don't drop below 14.1v at full tilt.
bumonskateboard6 Posted January 6, 2011 Report Posted January 6, 2011 Link your batteries together with one run of 0 instead of 2 runs of 6, you'll see an improvement in voltage. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
__d_a_v_i_d__ Posted January 6, 2011 Report Posted January 6, 2011 best is negative of a bat if its in the trunk Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
