voltage differences at battery and at amp
Hi everyone..
I got an Eclipse 3322 400 320watt amp in my 01 impala ls. It's being bridged to output 320 watts @ 4ohms.
I have two 6 gauge runs of pos and negative from the battery to my trunk. At the battery, and the fuse holder it's reading 14.23 - .28 when the car is idling. When the car's idling, at the amp, it's only seeing about 12.3 steadily. Any reason why? Why am I losing 2 volts from the front to the back?
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
because you ran a ground wire all the way from the battery probably. Shorten the ground so its only 1-2 feet long.
Hammerdown... 1%
upgrade your wire.
2011 Subaru WRX
Rockford Fosgate T1000-4AD
(2) Sets of Rockford Fosgate T3 6.5 Components
In the works:
Rockford Fosgate T2500-1bdcp
(2)DC Audio 12" XLM2
Oh really? I really only ran the ground to the battery because its my first system and am unsure of where to ground to in the trunk. Would the bolt holding down my seatbelts work?
First System
that could work but usualy those bolts are big. there may be a perfect size bolt on top of the shock tower if the car has struts. make sure u sand the paint around the area to bare metal too.
2007 caliber
2 Fi ssd 18's
rd audio 3250
xs power d3100 (need 2 more)
stock alt (soon to be singer 350a)
2.75:1 4th order in progress!
Don't use seat bolts or seatbelt bolts, they are crappy grounds. The best ground you can have is by drilling a hole through a good thick chunk of metal (not just sheet metal) and sanding down to bare metal and nut and bolt the ground there. Otherwise shock tower bolts work decent.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
Alright, yes the car does have struts. They are easily accessable. I will see if I can use one of those tomorrow when I get home from school before I hook up my RE SRX12D2.
Shortening the ground should most likely fix my voltage problem?
@Rebel and guy above him..
Alright so nogo with the seat belt bolts. I will take everything out of the trunk and try and find a better place than the strut towers to ground to. If i sand off the paint, should I use one of those washers with the pointy spikes in it to "dig" into the metal? Would that be a secure ground?
First System
Link your batteries together with one run of 0 instead of 2 runs of 6, you'll see an improvement in voltage.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
  • Who's Online   0 Members, 0 Anonymous, 1101 Guests (See full list)
