Sounds like something could be wrong with the woofers. Or possibly just a turn on pop. Most aftermarket headunits use a "soft" turn on so its gradual not immediately on. You could use a resistor on the remote wire. But I think this is unlikely to be the problem
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
a little over one ohm, and it should be a 1 ohm load, 4, 4 ohm VC. and i know i forgot to mention it, but the subs were fine after the incident with the heat, like, 3-4 hours later, they were ok. this issue started with the equalizer. Unless somehow a short formed a while AFTER the subs cooled off?
it is best to check each coil, not the total ohm load. check each coil at the terminals on the sub, withOUT the sub being hooked up to an amp.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Subs smoking do not end up okay (for very long).
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Subs are fine, why I love pioneer :) All the coils tested fine, and they worked perfectly on another amp. If anyone is still reading this, i actually found the problem, it was the RCA cable from the equalizer to the amp... a BRAND NEW RCA cable i might add, kinda pisses me off. but i changed the cable, and now all is good. but i have a new problem with the equalizer/preamp. i started a new topic though.
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
nvm...
Edited by El1T3Bass
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
