Rotten Posted January 13, 2011 Report Posted January 13, 2011 seems legit on paper... anyone runnin this amp??? 1ohm stable. and for 280$ seems like a possibility for a budget build. 3200w rms @ 1ohm oughta move two subs or so! haha Hi Speed Digital Circuitry New Hyper Bass 1 Ohm Stable Remote Dash Mount Low Level Gain Control w/ Cable PWM Power Supply 4-Way Protection Circuit Bridging Synchronization Variable Low Pass 40Hz-200Hz Variable Subsonic Filter 20Hz-50Hz Variable Bass Eq 0dB-18dB @ 45Hz Phase Switch 0 or 180 Frequency Response : 20Hz - 200Hz S/N Ratio : 100dB THD : 0.5% Master/Slave Function System Distress Indicator Dual Mono Speaker Output Connectors Platinum Plated Heavy Duty Power & Speaker Terminals SPECIFICATIONS Amplifier Class : Class D Number of Channels : 1-Channel Maximum Power : 5500 Watts RMS Power Output @ 4 Ohms : 1700 Watts x 1 Channel RMS Power Output @ 2 Ohms : 2500 Watts x 1 Channel RMS Power Output @ 1 Ohms : 3200 Watts x 1 Channel Bridged Power : N/A THD (Total Harmonic Distortion) : 0.5% Signal-to-Noise Ratio (dB) : 100dB Frequency Response (Hz) : 15Hz~150hz Built-in Crossover : N/A Subsonic Crossover Frequency : 20Hz-50hz Low-Pass Crossover Frequency : 40Hz~200Hz Bass Boost : 0dB~18dB Bass Remote : Yes Fan Cooled : N/A Fuse Rating :5x40a Dimensions (Width x Height x Depth) Inches : 17.1" x 8.26" x 2.16" Approximate Weight : 12.8 LBS -06' f-150... audio.video.performance.visual -08' yfz 450 all go. no sho
OBI Posted January 13, 2011 Report Posted January 13, 2011 200A worth of fusing. MIGHT get 2000watts outta it if your lucky. Probably closer to 1800 watts.
memphisBred Posted January 13, 2011 Report Posted January 13, 2011 If you get it clamp it. Won't do rated. SMD Super Seller/Buyer Audison----Hertz----Rainbow
Rotten Posted January 13, 2011 Author Report Posted January 13, 2011 yeah, im jus pokin around, lookin at stuff, going through options. SEEM'd oaky. hell, i know that orion hcca2.100 ive got wants like 200a+ per channel. but also been told that it will go clear down to .25ohm -06' f-150... audio.video.performance.visual -08' yfz 450 all go. no sho
Rotten Posted January 13, 2011 Author Report Posted January 13, 2011 now, if im thinkin right, arent most of the high power/low impedence amps externally fused? -06' f-150... audio.video.performance.visual -08' yfz 450 all go. no sho
zayres29 Posted January 13, 2011 Report Posted January 13, 2011 now, if im thinkin right, arent most of the high power/low impedence amps externally fused? yes this is true most (not all) legit mono amps are externally fused if it has internal fuses chances are its not going to do anywhere near rated unless the internal fuses are like 250/300 amp but ive never seen that Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
TeamHT Posted January 13, 2011 Report Posted January 13, 2011 yeah, im jus pokin around, lookin at stuff, going through options. SEEM'd oaky. hell, i know that orion hcca2.100 ive got wants like 200a+ per channel. but also been told that it will go clear down to .25ohm You're comparing and older model "cheater" amp built when the company and build houses were focused on quality. That Orion amp,and the amps they put out now aren't even in the same family. Tell me...does this smell like chloroform to you?
Rotten Posted January 13, 2011 Author Report Posted January 13, 2011 now, if im thinkin right, arent most of the high power/low impedence amps externally fused? yes this is true most (not all) legit mono amps are externally fused if it has internal fuses chances are its not going to do anywhere near rated unless the internal fuses are like 250/300 amp but ive never seen that yeah, thats what i though. i was thinkin this power acousitc amp was too good to be true. but then again seeing 200a worth of fuses also made me raise an eyebrow....i understand how it all works, but never personally meessed with anything more powerfull than my alpine amp... mono 1000w 80a worth of fusing... one day ill have a man system... my goal for 2011 is to break my 150db cherry. in my daily driven truck. haha -06' f-150... audio.video.performance.visual -08' yfz 450 all go. no sho
REMT15 Posted January 13, 2011 Report Posted January 13, 2011 for a few bucks more the audiopipe 3k is alot better deal. one of the best amps you can get for the price
