I've been in the business for the past 12 years, I've done my fair share of big builds.., but I've been roaming the SMD forums for the past week and checking out some of the builds going on here. I see one reoccurring theme(besides the big subs, lol), layer upon layer of mdf and 2.4's for the walls. I've never done a spl build, so seeing all those layers is completely new to me. One of my questions is, is there actually a noticeable gain in output from building them that way? Vs maybe using 1" MDF well braced internally? I've always been the type of installer who thought I should build everything so if this guy decides the get rid of the car/truck, we can yank it all back out and put it back to stock with minimum hassle, but after seeing some of the builds on here, I'm thinking of picking up a car to do one of these crazy spl perma-builds in. They've got me pretty curious. Another question was about the wiring, I've seen multiple alternators, but haven't really seen multiple 0awg's ran to the back, there's the possibility that I overlooked that part in some installs.
There can be big gains when its done right, but when you go overboard with the mutli-layer baffle its not doing anything. About 3 layers of 1" is usually enough for a wall, assuming you add a bit of internal bracing too. Maybe 4 layers if you're doing a 4x18 or something more..
As to the multiple 4/0 2/0 1/0 0/0 etc runs, yeah you've missed them. They're there. Some people go a little overkill with them though, and i've seen a lot of them improperly insulated (read my sig).
Hammerdown... 1%
using trippi's hummer as an example, ric used i think 2 or 3 layers of 3/4 or 1" thick wood, not mdf, pine is alot more light weight and alot stronger and gives off better sound to some people, so ive heard at least, anyways that wall does not even vibrate what so ever even when playing low notes, that wall is build like a damn ROCK
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
The layers are usually done as a precaution for playing very loud and very low. With a high tuned spl build you could get away with thinner walls without having to worry as much about stuff breaking. But the newer trend is to reach very high pressure levels at very low frequencies which is extremely destructive.
Thanks for the info guys, gives me some understanding about the layers, and now that you mention it, those low notes are pretty destructive, I ended up using fiberglass reinforcments inside the last big system I did because even with 1"mdf glued and screwed, it still managed to break apart the ports from the inside walls.
spl builds? These are daily drivers in a lot of cases. lol
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Most of the builds on here are ground pounders and daily rides.
So for pure SPL the techniques are going to be slightly different.
Usually 2x4s are good for the ground pounders,
but
For SPL its better to weld in a steel cage using square steel tubes, and fill the tubes with a polyester resin/sand mix to reduce resonance.
Then using Birch (not MDF) or Oak is preferred. Multiple layers is used for strength, and density. You can even use steel plates sandwiching concrete.
But 4 layers of Birch on the sides, top and bottom work well.
For the baffle, usually 6-9 layers of .75" works the best. Not only for rigidity and density, but for acoustic purposes. It gives the port it's length and keeps some back pressure from building up on the rear of the woofer cones.
When all done right. In a Super Street car, these types of enclosures are good for 170+ dB if you can manage to ever get that high.
The other types with 2x4s you have been mentioning are 160 dB boxes.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
resin/sand/cement mix is for 170+ cars
Ed Lester
ShowtimeSPL Host
My old Build Log
I have multiple runs of 0/1 in my daily driver. I only used 2 layers of 3/4 mdf, that it most cases is way more then enough strength. Some people on here kill trees using 2x4 for bracing, it is quite frankly a waste of wood. Sure 2x4's will brace, but there are far better ways to brace a ground pounder.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
