The official guns and stuff shoot the breeze thread
wish i knew as much about guns as you guys do.
:ninja:
There's only one true thing you have to know about firearms. They ALL have one end with a hole, be on the opposite side of the hole and you'll be ok.
Rolex you sicken me.
Just let me finish my pie
~ Juice
There's only one true thing you have to know about women. They ALL have one end with two holes, be on the inside of one of them and you'll be ok.
*fixed.
The before
Marked the rear trunnion, but after doing some research and looking at the rivet pattern I found out that I have a modified rifle rear trunnioun used on older AK pistols. I had to get the proper component to make it work.
Removed the plate
There no way that would have held up if I drilled and tapped that
Removed the sling loop from the handguard retainer to install the extended rail.
Ran into a snag when securing the rail to the barrel. It would "bottom out" on the handguard retainer and raise the rear end causing the rail to point downward so I improvised using an extra nut from a fuse holder (guns AND car audio how ironic) that filled the space needed in the rear perfectly.
Ground a couple pieces on foreground since Midwest Industries decided to put a QD socket at the bottom of the rail disturbing the keymod flow.
Hogged out the rear sight notch
I still get to use the irons with the dot
A4A19425-E59D-4CCF-BA75-849D0F8512B2_zps
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
anybody have any experience with buying 80% lowers and finishing them?
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
I've got s buddy who does them he has done like four of them. With all the shit I have registered with the atf there is no way I'd be able to justify one. If you get he jig it's not supposed to be d
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
